Colour registration issue on IR C5185
  • adeyemi
    • 378
    I have a mis-registration of the four colours on IR C5185. This would have been a simple issue on a Xerox with which I'm more conversant. Can someone pls help with some suggestions on this matter. Thanks
    Dgtal
  • its_just_a_copier
    • May 2011
    • 132
    Re: Colour registration issue on IR C5185
    First thing I would do is remove the transfer belt from the ITB frame and clean all rollers inside, if this belt is close to or over 300k it must be replaced. Second thing would be to go to Service Mode, Level 2, COPIER/FUNCTION/CLEAR/REG-CLR. This usually resolves the issue, follow it up by a Full Auto Gradation adjustment.
    • teckat
      • 16083
      older pub--------
      iRC5180_Color_Shift_Prevention _&_Correction.pdf
      this is the pdf for below > Front to Rear Trail Edge Blur and Second Side Mis-Registration Service Mode Setting Solutions
      SERVICE MODE (Level 2) > COPIER > OPTION > BODY REG-SPD
      iR5180 Blur_Miss Reg TP09-10.pdf
      service mode------LEVEL 1
      SERVICE MODE
      press Additional Functions Key (once)
      press #2 & 8 key at the same time (release both)
      then press Additional Functions Key again (release it)
      while in LEVEL 1
      for LEVEL 2
      entry > press Additional Functions Key (once)> then #2 key
      SUB-SCAN is in Paper Feed direction
      MAIN SCAN is FRONT to BACK <-> BACK to FRONT
      CLICK ON GRID PIC for BETTER VIEW
      this test print will show u your offset issues/
      in service mode LEVEL 1 go to --COPIER>TEST>PG>TYPE
      under TYPE select/input "6" -hit OK> Press Print button>
      don't forget to return TYPE back to "0"
      • adeyemi
        • 378
        Thanks guys, i guess i should be able to resolve the matter with these tips, i'll get back to you guys on this. Thanks once more.
        Dgtal
        • adeyemi
          • 378
          I am back here on this matter and i'm not smiling yet! Let me tell you what I have done so far:
          1. I have done the REG CLR and Auto gradation (full)
          2. I have cleaned up the transfer belt assembly and the sensors on the Auto Registration sensor PCB
          3. I have swapped the C with the K laser unit after resetting its lens motor cam to the home position to know if it is caused by the laser.
          4. I have done: Service mode 2: Function/Laser: LD-ADJ-Y, LD-ADJ-M, LD-ADJ-C. Enable with OK
          Problem persists after all the above!!!
          But I had a problem printing PG6. When in service mode LEVEL 1, I did --COPIER>TEST>PG>TYPE
          , when I do all these, it does not respond or print anything at all.
          So I guess what I need to know now is what to do to make it print PG6 and subsequently how to correct whatever colour displacement pattern is revealed on PG6.
          Thanks all in advance once again for coming to the rescue.
          Dgtal
            make sure paper is loaded in the top cassette or in PG test there is page pick or pg pick set this to
            1 top cassette
            2 second cassette
            etc
            Did you clean rollers and replace ITB? Overused drums can leak toner into the inside of transfer belt causing slipping.
            • teckat
              • 16083
              did u check the External Secondary Transfer roller position ?? is onside pitched ?
              Check the ITB drive gear unit\ they wear down _those slanted (helical) gears walk over each other-
              is your ITB Belt shifting after making the PG6 GRID PRINTS ?
              if so u need to adjust the rail position ITB SITS ON----
              • adeyemi
                • 378
                Hello guys,
                Thanks so far. I am finally able to print PG6, many thanks to Skynet....the tray set on PG PICK had no paper!
                Now i have a PG6 whose vertical lines are almost perfectly aligned, though a very slight misalignment is visible, i'm sure this level of displacement is not unacceptable.
                The horizontal lines are however not aligned at all for each colour. They are almost parallel though. I believe if i can close up the misalignment, i will be good.
                I again dismantled the ITB blew it out with air-blower and cleaned out all the rollers. I also checked the drive gear Teckat mentioned, it looks good. I opened the small cover over the ITB on the right side while running, and it runs smoothly implying that the drive gear is ok.
                But problem still persists!!!!!
                Could there be a soft adjustment or setting for correcting this problem?
                Dgtal
                • teckat
                  • 16083
                  Hello guys,
                  POST YOUR GRID PRINT------do u know how to run two color PG6 Prints ???
                  -is issue in MAIN SCAN (front to back/cross-feed)
                  or SUB-SCAN (paper feed)
                  -on what color/colors is the alignment off
                  Did u remove the PATCH SENSOR (Pattern Reader Unit) > & inspect>CLEAN ?
                  (Reader for individual color patterns) most important
                  Pattern Reader Unit.pdf
                  Did u Replace that External Secondary Transfer roller ?
                  There is no perfection on these COPY MACHINES/
                  LASER
                  Detecting/Correcting the Angle in Main Scanning Direction
                  BLACK pattern is used as the reference.
                  Controlling Synchronization in Sub Scanning Direction----
                  The synchronization in sub scanning direction is controlled with reference to the PTOP signal (image formation start signal).
                  - When the mechanism becomes ready for image formation, the PTOP signal (image formation start signal) is generated, turning on the individual lasers based on the signal. = in this order >Yellow>Magenta>Cyan>Black
                  Detecting/Correcting Color Displacement in Sub Scanning Direction
                  Yellow pattern is used as the reference------------
                  Correcting Image Displacement
                  - displacement of the photosensitive drum caused by replacement of the drum unit/toner container
                  ->displacement in sub scanning direction
                  - displacement of laser path caused by replacement of laser unit
                  ->displacement/angle in main scanning direction
                  - displacement in laser path length caused by changes in temperature inside machine
                  ->variation in magnification
                  To correct the discrepancies in images, the machine executes corrective control for image position; it detects displacement in color by forming a pattern of a specific color on the transfer belt and reading it against the correct position.
                  • adeyemi
                    • 378
                    I cleaned the PATCH sensor as you recommended. See my PG6 print attached. Like I said vertical lines are good. The problem is on the horizontal. Note that the yellow is present after the magenta lines. Second transfer roller cleaned but not replaced....could this be seriously responsible for the problem?
                    Dgtal
                    • teckat
                      • 16083
                      This is a SUB SCAN issue( PAPER FEED EXIT DIRECTION)---------as shown below> Yellow is down first> so everything to follow (M>C>BK) is referenced off that-
                      I would do a MANUAL ADJUSTMENT for ALL the LASERS
                      see pdf procedure >>>>>>>>iRC5180_Color_Shift_Prevention _&amp;_Correction.pdf
                      • adeyemi
                        • 378
                        see pdf procedure >>>>>>>>iRC5180_Color_Shift_Prevention _&_Correction.pdf
                        My question is how exactly can this manual adjustment can be done??? You already sent me the above pdf and it has been quite useful so far. It provided a lot of info and i found out how to resset all the lasers to home position manually in it, which i did. The idea i got from this bulletin is that if i do this, the machine can then automatically move the lenses of C, M, and Y (leaving K as reference) to give the proper alignment. But this is not happening. The machine moves the lenses quite alright, but not enough to correctly align the four laser guns. So how to specifically move each laser gun onto alignment with each other and bypass the machine's judgement (which i think is one way out here), it does not mention.
                        If you can describe this to me, you would have solved my problem for me. Thanks.
                        Dgtal
                        • teckat
                          • 16083
                          Laser info.pdf
                          what u do is remove (Take Out) ALL THE LASERS(see pdf)> ALIGN in position as in pdf.>
                          put them back> power up printer> then do a FULL AUTO GRADATION>nothing else----------
                          then check PG6----
                          Have u ever replaced the entire ITB UNIT ??
                          have u ever replaced External Secondary Transfer roller ?
                          Post a PG 10 from your printer--
                          one thing to check> make sure your each of your LASERS have their label information in SERVICE MODE under below settings>
                          Laser Manufacturer ID:
                          [1]COPIER > ADJUST > LASER > LA-MK-Y/M/C/K
                          Laser Magnification:
                          [2]COPIER > ADJUST > LASER > LDADJ1-Y/M/C/K
                          [3]COPIER > ADJUST > LASER > LDADJ2-Y/M/C/K
                          [4]COPIER > ADJUST > LASER > LDADJ3-Y/M/C/K
                          Laser Phase Difference:
                          [5]COPIER > ADJUST > LASER > LDADJ4-Y/M/C/K
                          [6]COPIER > ADJUST > LASER > LDADJ5-Y/M/C/K
                          [7]COPIER > ADJUST > LASER > LDADJ6-Y/M/C/K
                          • its_just_a_copier
                            • May 2011
                            • 132
                            Have you performed DCON clear yet?
                            • teckat
                              • 16083
                              techs used that on 3200 series/ usually image issue returns/ Lazy way out/ +u need a P PRINT to re-input values back from default as a result of the CLEAR----
                              Do not execute a “Clear DCon Controller” operation
                              , as it will
                              delete all the values entered for the Laser data. The effects of this clearing more often than not lead to more
                              confusion and problems, without resolving the fault in any way.
                              see Canon Pub>
                              http://www.copytechnet.com/forums/at...correction.pdf
