Change in the Fixing Web Pressure Spring
Products Affected: Serial Numbers Affected:
imagePRESS C1 All Serial Numbers
imagePRESS C1+ All ENS Serial Numbers
imagePRESS C1+ HMC00001 ~ HMC01315
A change made to the material used to manufacture the Fixing Web Pressure Spring (FU5-2867-010).
The change has been introduced to prevent Collection Roller contamination and eventual image failure due to Fixing Web Pressure Spring breakage.
Breakage of the Fixing Web Pressure Spring lowers the capability of the Fixing Web to clean the surface of the Collection
Roller. Diminished capability of the Fixing Web to clean the surface of the Collection Roller would result in a contamination of the Collection Roller.
The final consequence is a smeared image on the print.
--see pdf-
