Canon iRC 2620 system manager ID & Password
  • aknother1993
    [Electrical] Canon iRC 2620 system manager ID & Password
    I forgot My canon iRC 2620, system manager ID and password,
    how
    to clear for perform password ? thank in advance.
  • jiongpao
    • May 2009
    • 414
    Re: Canon iRC 2620 system manager ID & Password
    Hi. There are several threads similar as your question. When i searched from the history thread i found one of this but u can search more thread similar as your question
    http://www.copytechnet.com/forums/ca...-password.html
    • teckat
      • 16083
      Are u a SPY
      1) Go into Service Mode by hitting [Additional Functions-2 and 8-Additional Functions]
      2) Select [COPIER]
      3) Select [FUNCTION] (One of the buttons across the top of the LCD)
      4) Select [CLEAR]
      5) Scroll to screen two of the LCD using the Right arrow key.
      6) Select [PWD-CLR]
      7) Hit [OK]
      8) Hit the RESET button twice in order to return to the Main LCD Screen.
      This will turn off the Department ID Management feature on the machine (without deleting the configured Department IDs and Passwords) and will clear out (delete) the System Manager ID and Password.
      It might be necessary to Power the unit Off and then Back ON.
      NOTE
      If Dept. ID Management is turned on, before you can delete a Dept. ID, you must know one ID and password to get to Additional Functions.
      To delete one or more Dept. IDs, follow the steps below:
      1. Press Additional Functions from the Control Panel.
      2. Select System Settings.
      3. Select Dept. ID Management.
      4. Select Store Dept ID/password.
      5. Select the Dept. ID you want to delete and select Erase.
      6. Select Yes to erase the Dept. ID.
      7. Click Done 3x to return to the main screen.
      NOTE: If you do not know one of the Dept. ID and password, you must know the System Manager ID or you can set one up. If you do not know the System Manager password either, you then can delete the System Mgr password in service mode.
      • redzventures
        Service Tech
        • May 2009
        • 45
        Originally posted by teckat
        Are u a SPY
        [ATTACH=CONFIG]20819[/ATTACH]
        2) Select [COPIER]
        4) Select [CLEAR]
        6) Select [PWD-CLR]
        7) Hit [OK]
        NOTE
        I think you can also use 7654321 for the ID and password if you had not changed it. It may still work and worth a try.
        • teckat
          • 16083
          Not in this series
