canon3050 display error code E0010
  • cliffhangers
    • Feb 2010
    • 243
    good day,i need help on canon3050 it display error code E0010 plaese what can i do to solf this problem.waiting for solution.THANKS IN ADVANCE.
  • Scottb
    • Apr 2013
    • 306
    Re: canon3050 display error code E0010
    If i remember right that is a main motor code. I would check the fuser to make sure it is turning free, and go from there.
      • 23009
      Could that possibly be a Canon NP-3050, as in analog? That's been obsolete for at least 10 years.
      I don't see any main motor conditions in my database, because that's a typical problem of very old and tired machines. Turn each unit individually, looking for excessive drag. If I remember correctly there is one main motor driving most of the machine. If you don't find the problem there, start cleaning and lubricating bushings in the main drive. Don't just bathe the machine in oil. Take apart the various drive components, checking each for excessive drag or wear. Seized fuser bearings is the most common cause of main motor errors.
      Not that you can do much about it. Parts have been unavailable for a very long time. =^..^=
