E000007-0200
  • Hayk
    • 14
    [Error Code] E000007-0200
    Hello. After positioning fixing belt to center I restarted the machine, but still I'm getting this error. I really need help, as we don't have Canon service in Armenia. Thank you
  • Hayk
    • 14
    Re: E000007-0200
    Thank you for answer. Sorry i didn't mention, that the printer is Canon Imagepress C1
    • Barış KURT
      • Jul 2010
      • 72
      Re: E000007-0200
      i dont know about this model but eooo7 fuser film error other canon model (ir 2016 etc.).
      you must change it and clear code in service mode
      Black is Kyocera , Color is Gestetner.
        • 16083
        Re: E000007-0200
        sorry for jumping the gun------removed that 5180 info
        imagePRESS C1, imagePRESS C1+
        E007 0100 and 0200
        1-check the wire harness from fixing driver pcb, figure 810 key 55 part # FM2-7210-000 may resolve this code.
        (have see changing this harness help on this code in field)
        2-replaceing Fixing Driver PCB (FM2-7729-010) & Replacing M35 (FK2-0577-000)has also helped on this code
        3-Fixing Belt Walking =replacing the lower fixing belt/
        The steering roller bearings are wearing and binding the fixing belt assembly creating this issue.
        The following 3 steps where performed to correct the problem:
        1. Install a 100K Fixing Kit Kit#: F02-5186-000
        2. Install Steering Roller Bearings: Inner Bearing: XG9-0177-000 (2) and Outer Bearing: XG9-0407-000 (2).
        3. When assembling the fixing belt ensure to use the proper amount of oil so the unit does not bind and make noise.
        Quality Assurance Kits TP08-3.pdf
        iPRC1 E007 TP08-3.pdf
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Re: E000007-0200
          Replace GEAR, 36T FU6-0486-000 on fix. unit and read this PDF......ipc1-070.pdf
          • Hayk
            • 14
            Re: E000007-0200
            Thanks everyone, you are the best
