IR C6800 ADF doesn't initialize
  • daniboi
    End User
    • Oct 2009
    • 42
    Turning the machine on the ADF should initialize at first making it ready, the green light will be flashing. But it turns the other way, it doesn't initialize and I can't use it, the machine can print normally, I just can't use the feeder. I checked the sensors on it all good. connectors are ok, current flows, I can't isolate the problem. Need help on this please! Experienced techs save me here!
    daniboi
    • 16083
    Re: IR C6800 ADF doesn't initialize
    daniboi
    u talking about Original Placement Led
    check ADF cover, open/closed sensor-1 at J2, pin 11 on the ADF Controller for change of state
    • daniboi
      End User
      • Oct 2009
      • 42
      I thought I had checked all the sensors! And now you know I lied. I'll fix it tonight, I know this will be very helpful info.
      Thanks a lot.
      When I say thanks, it always come from my heart.
      daniboi
