When doing a copy thru the dadf , the copy's text is about a 1/4" higher than original ...off the glass its perfect ....and the how to is :-)
canon ir 105 copy not lined up
Re: canon ir 105 copy not lined up
Try to adjust the pick up tray assy to higher position until you get the right Y axis
Or you can adjust the Y axis at service mode COPIER, ADJUST, ADJ-XY, ADJ-Y-DF to higher value until you get correct alignment.
