ir4570 version H
  • jiongpao
    • May 2009
    • 413
    ir4570 version H
    Hi. I'm little confuse, may i know what is H version on Ir4570? Normally i saw N bootrom or C bootrom but i saw H bootrom today. What does it mean by H bootrom? Can it connect to computer for printing purpose just like N bootrom? And it come with fax board.
  • spectraindo
    • May 2008
    • 313
    Re: ir4570 version H
    Take a look at the Additionel Function menu, if there is a Printer Setting, probably it can function as a Printer.
    You can also press the Counter check and see what accessories are in the unit.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1250
      Bootrom version H = UFR II and PCL---yes, you should be able to connect it and print assuming that Version H is compatible with the IR4570 series(which it might not be..) I thought version H was only for the IR3530 series.
