Hi. I'm little confuse, may i know what is H version on Ir4570? Normally i saw N bootrom or C bootrom but i saw H bootrom today. What does it mean by H bootrom? Can it connect to computer for printing purpose just like N bootrom? And it come with fax board.
ir4570 version H
Re: ir4570 version H
Take a look at the Additionel Function menu, if there is a Printer Setting, probably it can function as a Printer.
You can also press the Counter check and see what accessories are in the unit. -
Bootrom version H = UFR II and PCL---yes, you should be able to connect it and print assuming that Version H is compatible with the IR4570 series(which it might not be..) I thought version H was only for the IR3530 series.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
