ir4570
  • akm
    • Sep 2012
    • 155
    [Misc] ir4570
    Dear CopyTech Team,
    I have a problem with IR4570 that gives a good copy but the back of the copy has a problem that a repeated faint band appears i change the lower roller pressure , primary roller ,drum sep, transfer roller , cleaning the dev. assy and add toner but still appear i want your help to solve the problem i will send attached sample of the problem
    thanks
    akm
    • 22999
    Re: ir4570
    What is the distance between the marks, in millimeters? =^..^=
    • akm
      • Sep 2012
      • 155
      Re: ir4570
      i am not at the office now i will messure the distance and tell you
      • mramlawi
        • Jul 2011
        • 838
        Re: ir4570
        Hello ,
        make sure that you are using an original Toner, also i want to ask you if the machine is clean from the inside and there;s no toner on it , what i initilaze that its a toner dust inside the transfer roller base , try to stop the paper befor enter the heater zone ,and clean the machine from the inside
        Distinguished road makes you jewel in rough
        • Simons
          • Jun 2008
          • 490
          Re: ir4570
          If you don't see anything on the drum unit bylooking at it then take out the developer and turn the roller. Changes are someone slipped while cleaning and put some crap on it.
          • Canon.Tech
            • Mar 2009
            • 335
            Re: ir4570
            Not literally I hope simons!?
            • akm
              • Sep 2012
              • 155
              Re: ir4570
              Iam sorry for late the distance is 5 cm almost
                • 22999
                Re: ir4570
                If your dimension is closer to 4.0 cm then it's a mottling issue. Remove the developing unit and rotate the developing cylinder. Watch for lumps, then dry wipe them.
                If the toner dumps in your shoes rotate the other direction. =^..^=
