Here is a known issue. If you install for example a Postscript kit in a machine that has been in service you can have network problems or not be able to print. Or if you reload system software you may see problems.
Solution. Update the machine. back up things if you need to. Perform a CLEAR ALL . This will cause the machine to need to be reinitialized. You will select your region, it will reboot then you will select language then it will reboot. continue setup. This lets the machine take FULL EFFECT of the updated software. Your network issues will disappear. Those issues can include wierd ping behavior too. No discovery behind a router but communicate with crossover. So finally in this case, the laptop is NOT the for sure rule out of machine problems. This is the only series I know that this is true. 1030if too. Plus the 1030if ssw is a .exe file that you run on a PC via USB. The SST tool is not used to update these machines.
Thank You all!
I try to test.
Br, N
The problem is solved by reloading the program two years ago
Correct!! The C1030 uses "User Support Tool" to update firmware.
