IR2018n paper jam
  • campo
    • Jun 2011
    • 15
    IR2018n paper jam
    Hi All
    Please help me fix this error.
    I tried to print and found jamming error.
    Then I found out that there are bits of paper looks like small mice feasting on paper inside the paper tray. Yes they were able to get inside the tray. After clearing the bits of paper the paper jam won't disappear.
    I have no service manual to guide me where those sensors are. I hope someone could help me fix this problem.
    I was wondering if there are other culprits causing this error like I need to reset a counter or something.
    Thanks in advance.
  • teckat
    • 16083
    Re: IR2018n paper jam
    Symbol /Name/ Function
    SR101 /Fixing film speed sensor/ Detects the fixing film speed.
    SR202 /Fixing delivery sensor /Detects fixing delivery.
    SR203 /No.1 delivery sensor /Detects delivery.
    SR204 /Cassette 1 paper sensor /Detects presence/absence of cassette 1 paper.
    SR206 /Waste toner full detection sensor /Detects the waste toner full status.
    SR207 /No.1 paper full sensor /Detects the No.1 paper full status.
    SR208 /Manual paper sensor /Detects presence/absence of manually fed paper.
    SR209 /Registration sensor /Detects registration paper.
    SR210 /Timing sensor/ Detects re-feeding.
    [1] /Humidity sensor PCB /Detects humidity.
    TH1 /Fixing main thermistor /Detects the fixing heater temperature.
    TH2 /Fixing sub thermistor /Detects the fixing heater temperature.
    TP1 /Thermo switch /Cuts off the heater power supply line when an abnormal temperature is
    detected.
    Jam Codes (Related to Printer Unit)
    0104 Delay jam in paper pickup section
    SR209 The registration sensor cannot detect the leading edge of paper from the moment paper pickup starts to the
    moment the jam detection time is reached.
    0208 Stationary jam in paper pickup section
    SR209 The registration sensor cannot detect the no paper status specified time before the leading edge of the picked
    up paper reaches this sensor.
    010c Delay jam in deliver section
    SR202,
    SR203,
    SR209
    - The fixing delivery sensor cannot detect presence of paper within the specified time after turning on of the
    registration clutch.
    - The fixing delivery sensor detected absence of paper within the specified time after the sensor had detected
    presence of paper within the specified time after turning on of the registration clutch.
    - The No.1 delivery sensor cannot detect presence of paper within the specified time after turning on of the
    fixing delivery sensor.
    0210 Stationary jam in delivery section
    SR202,
    SR203
    - The fixing delivery sensor cannot detect absence of paper within the specified time after turning off of the
    - The fixing delivery sensor cannot detect absence of paper within the specified time after the sensor detected
    the leading edge of paper.
    - The No.1 delivery sensor cannot detect absence of paper within the specified time after the sensor detected
    0214 Stationary jam in machine
    SR202,
    SR203,
    SR209
    Paper was detected in the paper transport path during initial rotation, during automatic delivery, at the end
    of cleaning, or at reception of an emergency stop command.
    1118 Door open jam
    SR202,
    SR203,
    SR209,
    SW2, SW3
    The door was opened when there was printing paper in the transport path.
    Jam history description (JAM)
    Item Explanation
    [1] Number The larger the number of a jam, the more recently it has occurred.
    [2] Jam date Date of jam occurrence
    [3] Jam time
    [4] Jam recovery time
    [5] Location 3: Host machine, 4: ADF, 5: Finisher
    [6] Occurrence category 0: Host machine, 1: ADF, 2: Finisher
    [7] Host machine 0104 Pickup assembly delay jam
    0208 Pickup assembly stationary jam
    010c Delivery assembly jam
    010e Second delivery assembly delivery delay jam
    0210 Delivery stationary jam
    0212 Second delivery assembly stationary jam
    0214 Host machine retention paper jam
    1118 Door open jam
    0120 Duplexing paper sensor 1 delay jam
    0221 Duplexing paper sensor 1 stationary jam
    0124 Duplexing paper sensor 2 delay jam
    0228 Duplexing paper sensor 2 stationary jam
    ADF 0000 Unknown jam
    0007 Initial stationary
    0008 Read sensor delay jam
    0009 Read sensor stationary jam
    000a Paper absence (Pull out the document.)
    000c Delivery reversal sensor delay jam
    000d Delivery reversal sensor stationary jam
    000e ADF cover open error
    000f User ADF open error
    0010 Pickup NG
    Finisher 0130 Inlet sensor delivery delay jam
    0231 Inlet sensor delivery stationary jam
    0033 Bundle delivery jam
    0035 Stapler jam
    1036 Power-on jam
    1137 Door open jam
    [8] Total counter display
    [9] Pickup stage position 0: Manual feed tray, 1: Cassette 1, 2: Cassette 2, 3: Cassette 3, 4: Cassette 4
    [10] Paper size
    JAM LOG EXAMPLE
    SERVICE MODE=press Additional functions key > then #2 key >then # 8 key > then Additional functions key
    2) Select "# REPORT" using < or > , and then press the OK.
    3) Select "REPORT OUTPUT" using < or > , and then press the OK.
    4) Select "ERROR LOG LIST" using ,< or > , and then press the OK.
    #REPORT
    #REPORT OUTPUT
    ERROR LOG LIST =Jam and error history output
    • campo
      • Jun 2011
      • 15
      I tried the service mode and I could only get to the Report output with error log list on the second line. Pressing OK will just create beeping sound.
      Sorry just a newbie here.
      • teckat
        • 16083
        -That's because your printer is still in a JAM situation? u need to remove paper jam/
        it's called "Investigate" to "Look"there are no short cuts--
        if u have a mouse issue in printer> u need to gut(remove Assembly's) to fully check(including checking the wires)
        Scroll until you see "# REPORT" hit OK
        Scroll until you see "REPORT OUTPUT" hit OK
        Scroll until you see "ERROR LOG LIST" hit OK
        • Canon.Tech
          • Mar 2009
          • 335
          Wow if you had had mice living in the machine maybe they have chewed through some wires!!??
          • campo
            • Jun 2011
            • 15
            I thought I could get into service mode (even with errors) to see the log and pinpoint the culprit.
            Yeah chewed wires could be possible too. I have scrutinized the bottom part where there are wires but found them intact. Not sure if the mice has entered the inner part of the machine. AFAIK they could only get inside the tray.
            • campo
              • Jun 2011
              • 15
              I see you posted parts and their life span. Will any of this parts at end life cause the paper jam error?
              So far the only parts replaced is the developing unit.
              [ATTACH=CONFIG]21002[/ATTACH]
              • northernlife
                • Sep 2011
                • 847
                So you cleared the jam, closed all the covers and it's still indicating a jam? If so is the LED indicating that the paper is still jammed in the lower left cover?
                • campo
                  • Jun 2011
                  • 15
                  Yes.
                  Actually, the copier did not even start the printing. There was no paper movement into the rollers. I noticed the blinking light so I checked and found the jam error but there was no paper in between rollers only bits of paper inside the tray chewed by the mice.
                  • teckat
                    • 16083
                    Yes.
                    • blazebusiness
                      SanDiegoCopierRepair.com
                      • 1257
                      Boy, Teckat----youv've got a pic for every occasion. LOL!
                      • songela
                        • Mar 2008
                        • 216
                        But he couldn't locate it in the Parts Catalogue
                        • aco.bk
                          • Sep 2012
                          • 130
                          check cassette retry sensor arm sticking on frame. Hook shaped part of arm on opposite side to where sensor arm makes/breaks sensor is the part that catches.
                          (Item 12 Fig 312)
                          • campo
                            • Jun 2011
                            • 15
                            (Item 12 Fig 312)
                            Looks like I need to remove parts to access the retry sensor. Do you have a guide on how to disassemble?
                            Thanks in advance.
                            • aco.bk
                              • Sep 2012
                              • 130
                              unfortunately I do not have!!
