Canon IR C 1030 if, Different size paper message
  • Doug James
    • Jan 2012
    • 935
    I haven't seen this copier yet but the customer says that he used the by-pass and hasn't been able to use this copier since. He has reloaded drivers etc...
    Any ideas on what the problem is... Thanks so much Doug
    • 16083
    Re: Canon IR C 1030 if, Different size paper message
    is stack bypass tray configured for custom page size./
    poor customer information !!!!!!!!!!
    Jams>Errors>Panel Messages
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5014
      Main problem is that customer did not read user manual.Usually is conflict between print and by-pass size.
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        The default setting on the 1022/1030 series for the bypass is disabled/off. If the customer turned it on/enabled it-so he could use it....either turn it back off or configure it for special paper size other than letter or legal(like envelope com 10) so the machine will pull paper from the cassettes and stop looking for the bypass. Seen this happen(paper size mismatch error) a lot on Hp printers as well.
          • 16083
          Setting Paper Size and Type.pdf
          click on pic----------
          Common Settings----iRC1022-1030 Common Settings.pdf
