Canon Imagepress problem
  • ramcess01
    • Jun 2013
    • 18
    hi My Canon Imagepress C1 is not recognized or detected by the computer so I can not connect to networks ... help me to install please
    thank you
  • teckat
    • 16083
    Re: Canon Imagepress problem
    thank you
    what is your set up for NETWORK PRINTING
    do u have a imagePress Server Q1/T1 connected ??
    or the COLOR UFR II/PCL/PS KIT-P1/or K1
    (activated)
    NOTE
    To use the features of the Color UFR II/PCL/PS Printer Kit, it is necessary to expand the memory capacity of the machine to 1,536 MB.
    OPTION>
    Color Universal Send Kit
    The Color Universal Send Kit enables you to send scanned documents via e-mail or I-fax, as well as send scanned data to be stored in file servers or User In-boxes.
    NOTE
    The Send function is available only if the Color Universal Send Kit is activated by registering a license key.
    You can check for the LMS-based Printer Kit on the Canon device the same way as you would check for any other installed LMS-based option or kit.
    Perform the following steps:
    1. Press the [Counter Check] button on the copier control panel.
    2. Hit the [Device Configuration] button on the LCD screen.
    3. Scroll down through all of the available pages on this Device Configuration screen. Look for either PS, PCL or UFRII. The methods listed here (ex. PS, PCL, or UFRII) are installed and are available for printing.
    • ramcess01
      • Jun 2013
      • 18
      Thank you for your reply but my problem is not yet solved because my network setup menu is different ... I enclose a photo
      • teckat
        • 16083
        do u have an external server ( Q1/2 or T1) yes or no
        if yes>Make sure in the service mode COPIER>OPTION>INT-FACE>IMG–CONT is set to "3" power off/on
        if u do> the u put your Network settings in/under (scroll to--> PRINTER TAB on control panel-Press the Printer Status/Settings menu
        if u have a Print KIT >make sure COPIER>OPTION>INT-FACE>IMG–CONT is set to "0" power off/on
        u put the Network settings under "Additional Functions"
        If you are configuring the settings for the first time, use the control panel of the
        machine
        • teckat
          • 16083
          • ramcess01
            • Jun 2013
            • 18
            I have T1 yes CONT set to 3
            do u have an external server ( Q1/2 or T1) yes or no [/QUOTE]
            • teckat
              • 16083
              if yes>Make sure in the service mode COPIER>OPTION>INT-FACE>IMG–CONT set to 3
              if u have a Print KIT > u put the Network settings under "Additional Functions"
              machine
              [/QUOTE]
              OK - now we're getin somewhere
              do u see the PRINTER TAB > on control panel > u may have to scroll to it in upper left corner
              look thru the install pdf>
              here is a guide for T1--
              T1_Installation.pdf
              T1_I&SG-1.pdf
              DRIVERS FOR T1
              http://www.usa.canon.com/cusa/suppor...ersAndSoftware
              • ramcess01
                • Jun 2013
                • 18
                Still nothing always the same menu different networks
                T1_Installation.pdf
                T1_I&SG-1.pdf
                DRIVERS FOR T1
                Canon U.S.A. : Support & Drivers : imagePRESS Server-T1
                [/QUOTE]
                • ramcess01
                  • Jun 2013
                  • 18
                  Hello
                  I have a problem with Canon imagePRESS C1 equip T1, is operating normally but is not detectable with my pc or networking or USB ... and according to the manual network setup in the screen of the machine I is the menu of the latest and differing manual I can not find access to IP ...imagepress c1.jpg
                  • ramcess01
                    • Jun 2013
                    • 18
                    hi
                    I tried everything but nothing
                    the menu does not change and I still do not have access to change the IP address or server
                    On aillers when accessing the status of the printer tjs he asked me to check the cable and lan connection
                    thx
                    • teckat
                      • 16083
                      hi
                      thx
                      Make sure u have the correct cable set up? see install manual
                      Crossover cable goes from T1 to Printer side
                      Ethernet Straight network cable
                      goes from T1 to your Network wall connection side
                      Interface Communications cable goes from T1 to printer side
                      • ramcess01
                        • Jun 2013
                        • 18
                        I checked everything with no result
                        • teckat
                          • 16083
                          remove the
                          TI Open I/F PCB in printer > and re-seat it
                          • ramcess01
                            • Jun 2013
                            • 18
                            this is already done but it does not change anything
                            • teckat
                              • 16083
                              NOTE: If you have an external RIP, such as an imagePASS J1/H1, colorPASS GX-100 or imagePRESS T1/Q1, you will not have any PDLs listed on the copier because there are no internal print kits installed on the device. In this case printing is controlled by the external RIP and you will still use the 'C' Boot ROM.
                              1-where did u get this TI ?
                              2-did try to reload the T1 system software ?
                              3- has someone confirmed the Network is active ?
                              4- did u read the Service Guide
                              5-are there any DIAG 2-digit display codes on T1
                              FF • iPR-T1 is not booting =Check external and internal connections and cables.
                              E3 • DIMM is missing =Install or reseat the DIMM in DDR DIMM2.
                              00 • iPR-T1 has booted and is functioning correctly = No action required.
                              if u don't have CD's
                              There are two ways to order v2.0 system software for the imagePRESS Server T1, they are as follows:
                              * DVD - System Software v2.0: FK2-5844-000
                              * Mediapack w/System Software v2.0: FM3-1062-000
