DADF-S1 jam before scan roller: code 0051
  • satitjangdee
    • Jun 2011
    • 49
    [Jamming] DADF-S1 jam before scan roller: code 0051
    Good Day GURU.
    My machine is IR5075 with DADF-S1 feeder, after I replace feed roller (because caramel rubber) it stuck.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: DADF-S1 jam before scan roller: code 0051
    Originally posted by satitjangdee
    Good Day GURU.
    Sounds like something was not assembled correctly. There is a pin that can drop out when you replace the feed roller. Maybe you are missing that pin. Also , there is a plastic separation guide that when reinstalled must be mounted so that the wider side of the sheet is toward the pickup roller side. If you are going to be working on your own machine.....buy the service manuals so you can familiarize yourself with the disassembly procedures my friend. Now you've got to retrace your steps and figure where you went wrong. Start by verifying that you didn't lose that small pin. I'll attatch a pdf in the hope that it will help you.......but buy the books, your gonna need them or eventually you'll make a bad mistake that will cost you some $$$$$$$$$$$$$DADF roller removal.pdf
    • satitjangdee
      • Jun 2011
      • 49
      Thank a lot for your advice Blazebusiness. I will try.
      • blazebusiness
        • 1257
        Welcome! Get those books my friend. Don't just wing it.
        • satitjangdee
          • Jun 2011
          • 49
          I just solved my problem.
          That was too narrow gap between 2 metal plates before enter the transfer corona.
          I compared to another machine that wide gap enough for paper pass smoothly.
          No. Paper Jam anymore.
          Thank you my friend.
