IR5075 fuser codes
  • Cycle Clutch
    • Feb 2013
    • 25
    [Error Code] IR5075 fuser codes
    IR5075 with E001-0001,E001-0002. Installed Canon rebuilt
    fixing assy., but code pops up a couple times a day. Line
    voltage is OK. Opened incident # with Canon Tech Support-
    they say possible DC Controller Bd problem-My gut says no.
    What have I forgot to check?
  • Luther
    • May 2006
    • 682
    Re: IR5075 fuser codes
    check the connector from the fuser to the main body on the transport section for paper broken pin etc., try a dc con clear, i have had dc controllers go bad
    • Cycle Clutch
      • Feb 2013
      • 25
      Thanks Luther for the response. I have removed the tran/sep-
      bed belt-fixing assy. from the copier and gave it a good looking
      over. All connector pins are good and clean. Just did the D-Con
      clear. Time will tell if it works. Thanks again.
      • Luther
        • May 2006
        • 682
        make sure you check the machine side of the connector also not just the transport section side, there was a mod to put 2 washers on the connector to ensure good contact, good luck
        • smiley
          • Aug 2008
          • 615
          hi. sometimes it was the bad fixing shutter.
          there is no glory without sacrifice
          • Cycle Clutch
            • Feb 2013
            • 25
            It's been 2 weeks since I did the DCON clear, and there have been
            no more codes thrown. Thanks Luther!
