colorpass z500e not starting up
  • carlosramosdrum
    • Sep 2012
    • 45
    Hello. I have a colorpass z500e not starting up. freezes at halb bar. i thnik if i reinstall the system software on it i can bring it to life. can you plese inform me how can i reinstall system software on this colorpass? i tried 4 buttons at start up and lower right button to see if some recovery menu apears but nothing. i cant find the manual for this one.
  • KL568
    _
    • Feb 2011
    • 324
    Re: colorpass z500e not starting up
    Hi,
    The button you are pressing is correct, I might be wrong but I think that only works for Z400e range. You's is WinXPe system so it will need a external SCSI CD drive plus the system CD to reload.
    Does your Z500e allow you to plug on a monitor? No harm trying it with a keyboard to see if it has an option to restore.
    • carlosramosdrum
      • Sep 2012
      • 45
      • carlosramosdrum
        • Sep 2012
        • 45
        i tals z40 but they are all z40e with windows nt.
        • teckat
          • 16083
          could just be a defective SCSI PCB Assembly.
          ColorPASS Z40 / Z40e / Z20e / Z400e / Z500e / Z4500 / Z4600 / Z3000 models do NOT support connecting the Advanced GUI Kit from Canon or any monitor, mouse, or keyboard.
          An external SCSI CD-ROM drive is required. Connect the CD-ROM drive with a SCSI-2 cable to the SCSI port on the back of the ColorPASS. Power on the CD-ROM drive. Place the system software CD in the drive and turn on the ColorPASS. The RIP should then prompt you to install software.
          The ColorPASS Z800 / Z7400 / Z7500 / Z7000 / Z7100 / Z6000 / Z6100 / Z5400 / Z5100 / Z5000 / Z4600 / Z4500 / Z650 / Z600 / Z500e come with a CD to restore the system software from backup.
          These ColorPASS models do not have a Restore from Backup option built in (like the 1st generation ColorPASS-Z series controllers), so the Restore from Backup CD must be used to perform a restore from backup.
          You cannot perform a Restore from Backup on the ColorPASS Z500e without the Restore/Update CD.
          • carlosramosdrum
            • Sep 2012
            • 45
            thank you so much.
            this is a used rip. where can i download system software iso? do you have it?
            it is very nice if someone can send me. i will have to buy a scsi cdrom. do you know some cheap one?
            • teckat
              • 16083
              thank you so much.
              scsi cdrom
              GOOGLE for it> or go to Goodwill > or a Pawn Shop
              • carlosramosdrum
                • Sep 2012
                • 45
                will an internal scsi cdrom work if connected to the inside scsi board connectos?
                this one: http://vilanovadegaia.olx.pt/leitor-...-iid-432566929
                • carlosramosdrum
                  • Sep 2012
                  • 45
                  will this be perfect for the job?
                  thank you so mutch
                  • teckat
                    • 16083
                    thank you so mutch
                    yes
