IR 3245 fixing film failures??
  • skibum
    Independent Service Tech
    • 231
    I have a IR3245 that keeps having a premature failure of the fixing film (E-000007) about every 20K - 40K. The last time we replaced the whole assembly and it failed after 43K. I have a number of 3045's that make it to 100K approx. Any ideas would be helpful.
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: IR 3245 fixing film failures??
    Hello,
    Replace the film by a genuine one and move the machine to another place because this issue may be caused by a bad ground level.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • Luther
      • May 2006
      • 682
      i went thru the same thing, it was uneven pressure from the pressure screws, had tons of failures then checked the pressure screws and the pressure was uneven, there was an earlier post that had the procedure for checking the pressure, do a nip check in service mode and you will find the pressure being uneven, hope this helps
      • Rachid.Akli
        • Oct 2011
        • 595
        The fixing assembly has been replaced and the issue is still the same.
        Rachid.
        • Canuck
          Tech Specialist
          • 1713
          Known issue on these machines. If nip,etc is ok,check the mount brackets the fixing assembly mounting screws go into. These brackets are secured by two screws with red Loc-tite on them. Make sure these brackets are centered in their locating holes and straight and perfectly vertical. If not, crack the screws loose and adjust it. If they look centered and film walks to rear of machine,raise the rear bracket about 1 mm. Also make sure there is white grease on inside ends of film where it rotates on the black plastic holder. A dab of white high temp grease helps if dry
          • apollo
            • Mar 2008
            • 176
            If the fuser film is tearing at edge, causing E0007, I would check copier is level both side to side and front to back.
            place spirit level on glass and level.
            Had few issues film tearing as machine not level .
            • teckat
              • 16083
              Rachid.
              the rear screw that applies pressure between the fixing film and the pressure roller can become stripped. This creates uneven pressure which then causes the film to track improperly until it tears and generates a E007 code.
              workaround is to replace the stripped screw with a longer screw or replace the fuser assembly. Also, do not overlook the screw hole in the metal making sure the threads are intact.
              • teckat
                • 16083
                see pdf adjustments
                Measure to Prevent Displacement, Breakage of the Fixing Film and E007-0000
                • northernlife
                  • Sep 2011
                  • 847
                  You will also get a wrinkled LFR from what I've been running into.
                  • Canuck
                    Tech Specialist
                    • 1713
                    see pdf adjustments
                    tada...I have Canadian version of same document
                    • teckat
                      • 16083
                      Originally posted by Tikin
                      This definitely helped a lot. We had replaced two fixing assemblies and it turns out it is the bracket on the actual machine that was not centered.
                      Welcome, 🍺
                      • Canuck
                        Tech Specialist
                        • 1713
                        Shoulda read my post here from 4 years ago....I said to move the brackets...lol
