dear senior technicians, and other friends, this is my first visit and hello to every body. i need a help to convert basic copier of IR7200 as a printer. i replaced printer boot rom FG6-8855 Ver .23.40 N and IR600 ethernet pcb. but it can't work as printer. i also note that ther is no the word BOARD in display, when i go to service mode. from service, manual i came to know that there should be two more boards -LIPS PCB and RAISER PCB are needed. what size memory i need to fix. main controler part number is FG6-7278. CAN ANY ONE GUIDE ME TO FIX THIS PROBLEM? THANKS TO ALL!
Ir 7200 printer details enquary
Re: Ir 7200 printer details enquary
Network Multi-PDL Printer Kit -B3--------------------------
U need to load in the iR7200N Firmware > using SST
Memory=Uses Main unit DIMM (192 MB)**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
thank you mr .teckat! i down load the system software N version as you told . now printing problem solved. again thank you sir.Comment
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
