C5185 - scan glass message
  • kuby
    • Oct 2007
    • 1408
    Is there a way to turn off the message to clean the scan glass? I have set the two indicators to "0" but the message still comes on.
  • teckat
    • 16083
    Re: C5185 - scan glass message
    under Additional Functions
    >User Modes
    >COMMON SETTINGS>look for >(Display the Cleaning of the Document Reading or READ AREA CLEANING) depending on model set this to " OFF"
    Stream Reading Dust Detection Control
    The machine checks the stream reading glass and the ADF platen roller for the presence/absent of dust.
    It then changes the point of reading or executes image correction depending on the result of detection, thereby avoiding reproduction of dust particles in its output images. The machine executes the detection mechanism only when the ADF is used:
    if changed >>>>>>>>>>>>>>>>>>>
    U need to put back the P Print settings for
    COPIER>OPTION>BODY>
    DFDST-L1
    A higher setting will increase the level of dust detection (i.e., the machine will be more sensitive in detecting dust, which if left
    behind will cause thin lines in the images).
    settings range
    0 to 255
    [Factory default/After RAM clear: 200]
    DFDST-L2
    settings range
    0 to 255
    do not leave these settings at "0"
    • Canuck
      Tech Specialist
      • 1713
      I set them at 50. Do all of the ccd adjustments for platen copying and document feeder. Run STRD-POS to find a nice place on glass to read from. Clean the white plate under the glass(for shading correction).
