E0000009-0500
  • ratherbehunting
    [Error Code] E0000009-0500
    Lap top crashed no access to my manuals. Had a 0000008 0001 replaced entire fuser assebly and rails with a working unit. Tested before arrival. 8 cleared now getting the 9 dash 500 can anyone help so I can get paid and out of here.
  • Canuck
    Tech Specialist
    • 1713
    Re: E0000009-0500
    Model please. Usually an E-008 indicates fuser roll or fixing unit is at end of its life. If you replaced the fuser you have to reset these counters in service mode. Only E-009 i can think of is on an irc6800. Fault with external heating roll movement..let us know the model and go from there.
    • teckat
      • 16083
      Re: E0000009-0500
      mind reader for hire
      • ratherbehunting
        Re: E0000009-0500
        Totaly forgot model, C5185i. More info available. Not a fixing unit problem. Swapped out 4 all fuser related errors. Installed into another machine and the units work fine. Was told next step is main pcb. Is this true and what are procedures for main pcb replacement.
        • vigour
          • Aug 2010
          • 1038
          Re: E0000009-0500
          Suggested causes are:
          -Fixing pressure release Home position sensor
          -Fixing Pressure motor
          -DC Controller 2 (Maisy)
          • teckat
            • 16083
            Re: E0000009-0500
            as vigour posted ==DC Controller 2 (Maisey)
            check your connections have also seen connection issues (on Frame side) for this as shown in TECH PUB>>>
            see pub.Minimizing Error Codes---TP09 205d.pdf
            also check Relay/Driver PCB PCB >>>> have also corrected e009 a few times by replacing this pcb> think it was a fuse issue on board>>
