always please wait in IRC 3220
  • mido
    • Nov 2011
    • 177
    Hi all,
    I have a problem in CLC 3220, the machine always display (please waiting), after clearing the dc cont and MMI, plz I need your suggestion about this problem,
    Regards
  • teckat
    • 16083
    Re: always please wait in IRC 3220
    Originally posted by mido
    Hi all,
    Regards
    Displayed When Sending Print Jobs
    does printer come to READY & then go into waiting
    or does the opening splash bar hang up & say please waiting
    u just can't clear DCON without having a P PRINT with the DCON settings to put back in printer/
    do u have a Fiery connected ??
    if so =Try re-seating the Open Interface Board
    how old are the DRUMS ??
    Check to see if the Fuser unit is coming up to temperature.
    Then check to see if the drum unit(s)are not past the life expectancy.Replace the drum unit(s) if needed.
    could be caused by a loss of communication between the DDI-S PCB Board to the Main Controller.
    remove memory & clean ends >then re-seat
    • mido
      • Nov 2011
      • 177
      Hi,
      • Displayed after reboot the startup .
      • No still waiting
      • No , the opening splash bar end and open new window then waiting to warm up
      • I print the p print before cleared the DCON but I cannot enter the service mode by *28*
      do u have a Fiery connected??
      • Yes I have a fiery c1
      • I will try
      how old are the DRUMS??
      • All the drums counter are low reading
      check to see if the Fuser unit is coming up to temperature.
      • I touched the fuser unit the temperature was high
      Then check to see if the drum unit(s) are not past the life expectancy. Replace the drum unit(s) if needed.
      • I don’t think, because it was working before clear the DCON and MMI,
      There was a problem in the copy or print out, a shadow of the letter in both mode, I changed the ITB but not solved, one of my friend suggest to clear the DCON and MMI , so I did
      • I will try
      Thanks for your support
      • Canon.Tech
        • Mar 2009
        • 335
        Have you set IMG-CONT back to 3 after doinging the performing the clear? do you have the printer tab on the top right of your screen?
        Verify that the copier is set to 'imagePASS mode' (IMG-CONT = 3): 1. Enter Service Mode by hitting Additional Functions, 2 and 8 simultaneously, and then Additional Functions.
        2. Select Copier > Option > INT-FACE > IMG-CONT.
        3. Set IMG-CONT to 3 and hit OK.
        4. Reboot the copier.
        * When IMG-CONT is set to 0, the copier is set to use the Canon Printer Kit controller. The Printer tab will not be displayed.
        When IMG-CONT is set to 3, the copier is set to use the imagePASS controller. The Printer tab will be displayed.
        • teckat
          • 16083
          great point on re set/ overlooked that MMI Clear by poster
          Reminder to poster >
          >power off printer> then remove all the Fiery connections> power up printer get into service mode ( U NEED TO BE QUICK> u may have to try a few times) then do procedure to re set fiery as posted by Canon.Tech.
          1-after re set/ power off>connect back fiery>power on>
          imagePass C2 Install.pdf
          • mido
            • Nov 2011
            • 177
            Hi,
            I verified the IMG-CONT=3, it was the same value, but I press ok again, then restart the copier, then it work well.
            Thank you Canon Tech and Teckat for your help
