ir 2016 Error 007
  • ernesto
    • Oct 2011
    • 430
    ir 2016 Error 007
    Hi
    does anyone know if there is any adjust to ignore Error EOO7
    and so the fixing unit of the ir 2016, ir 20xx could continue working?
    I hope to hearing from you soon
    all the best
  • songela
    • Mar 2008
    • 216
    Re: ir 2016 Error 007
    Originally posted by ernesto
    Hi
    all the best
    For what reason would you choose to cheat the machine to ignore the error message, that calls for replacement of either the fixing film or the fuser unit.
    • Andyboachie
      • 185
      E007 have to deal with anything about the fixing film. Carefully observe from the fixing unit to see if the film have displaced. It will be ideal to change the film completely. In correcting this ensure that the white rectangular area at the right hand side of the fixing film faces the thermostat properly. If it does not, you may though have changed the film, the E007 will still show. Try this before you consider any other option.
      • canonbundy
        • Jun 2012
        • 607
        Hi
        all the best
        You cannot ignore this code ......The Fixing Film WILL be TORN!!!!!
        • savi0r
          • Sep 2010
          • 363
          Hi. E007 means that the sensor does not detect the rotation of the fixing film. There are 2 causes :
          1. the fixing film is broken,damaged,etc.
          2. The film is ok but it does not rotate
          My advice is change the fixing film. Go for the original Canon film. Very important : observe carefully where the film is broken. If it has moved to one of the sides and got torn there, then you must change the pressure roller bearings or else the new film will have the same fate. Clean very well the fixing film unit and then on the heating element apply the special vaseline. Do not abuse it. After all this, rotate the film manually and see if it rotates without problems.
          Good luck.
          • ernesto
            • Oct 2011
            • 430
            Hi,
            This unit film could be still working if the error E007 could be ignored.
            I had this idea when I was checking a fixing film of the canon IR 1018 that was worse than the fixing film in the picture
            and the customer was working with his machine without problems.
            If the machine had been a IR 2016, the error e007 would have appeared.
            All the best
            • canonbundy
              • Jun 2012
              • 607
              [ATTACH=CONFIG]21501[/ATTACH]
              Hi,
              All the best
              WTF
              • savi0r
                • Sep 2010
                • 363
                Try to rotate the film manually. See if it rotates smoothly. If not, apply a new grease on the heating element and put the old fixing film back in. Like i said, with an original film, new bushings, new grease, asumming the other parts are ok, your fuser will work just fine for at least 150k copies. When was the last pm done on the copier? What's the counter? Any ideea when the fixing film was changed? We could use a little background.
                  • 23007
                  The only thing that I can add to this conversation is to talk about the white patch. That's how the machine determines that the fuser film is rotating. You can get E007 for a few different reasons:
                  - The film may not be rotating.
                  - The film may be torn so that the white patch has migrated away from the sensor.
                  - The white patch may not be white any more.
                  The last situation came up last week. I tried cleaning the patch and only succeeded in removing the remain whiteness from the film. I don't know if there is an aftermarket film available for this machine, but that may be an option.
                  The machine will not ever ignore an E007 message. =^..^=
