dc controller
  • edpianix
    • 30
    [Error Code] dc controller
    the machine that we have canon ir 5055 got an error e 000025 00001
    any body can help us
    i ask a friend this error is found in d c controller and need to be replace. but the problem is, it is too expensive and besides no where to buy.
    thanks
  • Luther
    • May 2006
    • 682
    Re: dc controller
    its and error for the toner bottle motor, replace the motor and check to make sure you have the right toner bottle in the machine, if you replace the motor and still get the code i think it blows f9 on the dc controller
    • canonbundy
      • Jun 2012
      • 607
      Re: dc controller
      thanks
      1. Check that the Toner Bottle has not been damaged and is fitted correctly.
      2. Check for hardened lumps of toner in the Sub Hopper.
      3. E025-0001 replace DC Motor M9 (FK2-0813-000). To check the Toner Supply Motor in Service mode [COPIER > FUNCTION > PART-CHK > MTR > enter "20 (CW)" or "21 (CCW)" > MTR-ON > OK]. Before executing this service mode item ensure the toner bottle is fitted to avoid a toner spill.
      4. E025-0002 and E025-0003 replace DC Motor M10 (FK2-0015-000). To check the Toner Stirring Motor in Service mode [COPIER > FUNCTION > PART-CHK > MTR > enter "22" > MTR-ON > OK]. Before executing this service mode item ensure the toner bottle is fitted to avoid a toner spill.
      5. Replace open FU15 (fuse) close to J103 on the DC controller which supplies 24volts to M10.
      6. Replace the DC Controller PCB Assembly (FM2-3646-000).
      • teckat
        • 16092
        Re: dc controller
        thanks
        call for a trained tech to inspect before attempting to replace expensive parts
        • edpianix
          • 30
          Re: no error
          we got a problem with canon ir 5000, the developing unit got empty or no toner inside. the hooper has plenty of toner. we already perform the *28 following the toners installation until it reach to ready state. but the problem is only few copies can be make the developing unit no toners left. is anybody encountered this problem?
          I really need your help.
          thanks
          more power to these site
          edpianix
          • vigour
            • Aug 2010
            • 1038
            Re: dc controller
            Remove or open the hopper cover.
            Try a dump.
            Watch if the stirring blades move.
            The toner could be hardened.
            The stirrer broken, or not turning
            • edpianix
              • 30
              Re: dc controller
              the stirrer rotates in the service mode. after few copies the developer got empty. i need more help.
              thanks God bless
              • vigour
                • Aug 2010
                • 1038
                Re: dc controller
                How do you know the developer is empty. Did you open it?
                You can fill the dev manually by opening the top and pouring some toner in it with a piece of paper or funnel or something like that..
                That will get you going.
                • edpianix
                  • 30
                  Re: dc controller
                  i open it and it is empty. i pour toner then run the machine but still the developer got empty. is there anybody their can help us.
                  • Canon.Tech
                    • Mar 2009
                    • 335
                    Re: dc controller
                    Sounds like the toner sensor in the dev unit is faulty, it's not calling for toner from the hopper. When the hopper is empty, clean the sensor, you should hear a very high pitched whine when it's working OK.
                    • spectraindo
                      • May 2008
                      • 313
                      Re: dc controller
                      Check the Toner Sensor in the Developing Unit, you can replace it with the one in the Hopper.
                      • Canon.Tech
                        • Mar 2009
                        • 335
                        Re: dc controller
                        ^^^^ So basically what I said!? ^^^^^
                        • jose antonio
                          • Dec 2012
                          • 119
                          Re: dc controller
                          Had this same problem on an IR-5055, finally it was the DC controller, but like teckat said make sure all sensors and motors are OK before replacing this part.,
                          very expensive! Good luck.
                          jose Antonio
                          • edpianix
                            • 30
                            Re: dc controller
                            thanks to all that is part of this website. the error code e00025 - 00001 is really in the dc controller board particularly in f015.
                            sense the F 015 is not available in the local electronics store i just solder very fine wire as fuse.
                            once again thanks.
                            more power to our site.
                            • teckat
                              • 16092
                              Re: dc controller
                              once again thanks.
                              it better be a low voltage Fuse
                              -that u bypassed with that fine wire to solder / if there is a short somewhere u will FRY the board completely
                              have seen techs use a paper clip to bypass a Fuse on 3200 Fuse boards / result is more damage
