Solution for Removing Canon NP4835 and 4335 drum unit
  • Andyboachie
    • 185
    Hi does anyone know the service code for removing Canon NP 4835 and NP 4335 drum unit?
  • Brian8506
    • 1664
    Re: Solution for Removing Canon NP4835 and 4335 drum unit
    Wow! Old one. If theres no handle to move dv away from drum, then its in service mode. Pinhole near fuser know has switch behind it. Activate with paper clip. I believe its in * 4 * and is called dev-xxx ( not sure of second part) That moves dv away from drum. I'm real deep into my memory now. I hope I helped.
    • Andyboachie
      • 185
      Thanks Buddy!
      It is really an old one. Your effort is so useful to me.
      • charm5496
        • 2387
        holy crap....I worked on these 20 years ago now. I am surprised that there are some still kicking around....that is too funny!
        • COPIERTEC ASSOCIATES
          • Aug 2011
          • 279
          Indeed these are old stuff and surprisingly are still working in the field.
          However,for the 4335,the drum is removed manually,by turning a black lever to the right of the dev unit.
          As for the 4835,do the following;
          1.Actuate the door switch ;2.Actuate service switch$;3.press*4*;4.use the arrow facing down to
          search for DEV,REL;5.use cassette select key to excute the drum release.The dev unit will then seperate from the drum unit.
            • 22999
            That's it! developer release. If there's a color unit, be sure to remove the color unit before you do the shift, because the developing units cam simultaneously, color in/black out or color out/black in.
            Also, if you attempt to clean the optics, be especially careful cleaning around the colored filters in the lens unit. It is very easy to knock out the colored filters, then have a hell of a time getting them back in.
            Can you actually get parts for this old beastie? =^..^=
            • Canuck
              Tech Specialist
              • 1713
              Check with Moses or Jesus for parts.....Noah had one of these on the Arc
