Hey guys,
I need some expert assistance. I am working on a IR7095 and when I print test page 7, to test solids, letter size seems fine but 11x17 is very faded with some blank areas. Here is a scan of the document.
20130725150344.pdf
I have searched the forum for some ideas and haved tried everything I found. I have checked the drum potential and it seems to be within range. VLT is 62, VLM is 67. VDM is 397, VDT is 405. I have swapped the laser, primary corona, pre-transfer, trans-sep, process unit with the drum, DV unit. I checked the dust proof glass and cleaned it. I checked the blanking lamps and they are coming on. I also swapped the HVT, High Voltage board, HV-AC board and the DC Controller. I checked the transfer corona block and it looks good and clean. No breaks or cracks. I'm at a loss. Does anyone have any suggestions? Why would letter size be fine, but not 11x17? Thanks for any help you can give me.
20130725150344.pdf
