having problem with ir 9070 image
  • rdc
    • 53
    have issue with image not on every book 12 pages half the books print good other half dont ..light print on second sheet, but not on every sheet..thought i found problem when i found lower roller bearings bad in fuser.. prints other pages without issue. just started this issue on this job just getting started on three hundred book run with cover and 6 double sided sheets.. help if possible..thanks ahead of time..could corona wire cause this, i have printed some other test sheets with different text 20 double sided, no problem..it just does one sheet bad every other book..
  • canonbundy
    • Jun 2012
    • 607
    Re: having problem with ir 9070 image
    Yeah, sounds like T/Sep Unit end blocks breaking down or HV Block at rear of Fixing Drawer - replace T/Sep Unit 1st.
    • Canuck
      Tech Specialist
      • 1713
      How old are corana wires? Probably transfer as stated. Rewire all the coronas before you start changing assemblies.
      • rdc
        • 53
        cleaned with elec. contact cleaner started working normal..im new to this help a friend from time to time..my profession is machinist .auto transmission in cars for thirty five years.thanks for help guys!!!
        • canonbundy
          • Jun 2012
          • 607
          Wow, cleaned with Contact Cleaner and it works - not bad for a Newbie.
