Canon irc 2880 copy quality problems
  • lagustacat
    • Oct 2010
    • 51
    I am working on a Canon IRC 2880, copy quality problems and print quality same, i have attached copies of this, replaced all drums and ITB unit, still same problem, can anyone help
  • Dan Dryer
    • Jan 2008
    • 57
    Re: Canon irc 2880 copy quality problems
    Clean the ATR Sensors, then perform a full Auto Gradation adjustment.
    If that fails to correct it, you could be looking at an ITB drive problem.
    • teckat
      • 16083
      Run Auto Color Mismatch Correction ==========
      Auto Color Mismatch Correction corrects Color Registration issues. To access Auto Color mismatch correction, select the following.
      Addition Functions > Adjustments and Cleaning > Auto Color Mismatch Correction
      *(If Auto color correction mismatch is not an option, be sure to update the firmware to the latest version. To clean the patch sensors manually actuate the solenoid to open the shutters and wipe the sensors with a dry lint free cloth.)
      ---then do A Full Auto Gradation
      Some registration problems can be resolved by clearing out the Registration Data stored in the DC Controller. To clear the data, perform the following.
      Enter Service Mode: Level 2 > Copier > Function > Clear > Reg/Clear. Highlight Reg/Clear and press OK.
      After performing the clear, reboot the machine and perform a Gradation Quick Adjust and then a Full Gradation adjust.
      SERVICE MODE-Level 1=
      press Additional Functions Key (once)
      press #2 & 8 key at the same time (release both)
      then press Additional Functions Key again (release it)
      to continue
      for Level 2 =press Additional Functions Key again > release> then press #2 key
      Note*
      Following the instructions above could prevent you from having to perform a DC-CON clear, and inputting all DC-CON values from the door label.
