Canon Gp335 scanner problem!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Electrical] Canon Gp335 scanner problem!
    Hi to all
    i have Gp335 , when i want to copy and press the green key , the xenon lamp light 3 secand and stop , and the scanner does't moves !!!!!
    can any one help me!
    thank you in advance.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • teckat
    • 16083
    Re: Canon Gp335 scanner problem!
    Originally posted by sweet.persona
    Hi to all
    0000000000000000;
    take of glass> move out all the way to right> power off/on printer>
    does scanner move back to home
      • 22999
      It sounds to me like the exposure lamp has not reached the proper intensity. Check for error codes stored: E220, E301, E803 and protection jam 0400.
      Also check that lamp heater has not slipped around, covering the lamp intensity sensor opening.
      Also check exposure lamp for blackened ends or arcing contacts.
      • sweet.persona
        Engineer
        • Nov 2009
        • 414
        thank you friends
        i tried to take of the glass and moves the scanner in the end , but when i turn power On scanner does't return to the first position! and when i start copying the lamp light abit and it sound 3 bip and all keys stop , and machine displaying (PLEASE WAIT...)
        DAMENE ABDEL AZIZ
        DJELFA
        • Canon.Tech
          • Mar 2009
          • 335
          Also check the home position sensor, clean it out, they fill up with dust etc & can cause odd faults with no error code.
          • teckat
            • 16083
            Hi to all
            -The No. 1/No. 2 mirror mount is driven by the scanner motor (M3). The scanner motor is a stepping motor, and is controlled by the image processor PCB.
            The position of the No. 1 mirror mount is detected by the scanner home position sensor (PS1).
            The scanner fails to move forward/in reverse.
            -Is the scanner drive cable routed correctly?
            -Is the scanner rail free of dirt, and does the scanner move smoothly?
            -Is the wiring/connection from the connector J116 on the DC controller PCB to the scanner motor through the relay connector
            J28 normal ?
            Replace the scanner motor or DCPCB
            Scanner home position sensor=PS1
            E202 (The scanner home position is not detected.)
            Is 5 VDC present at J112-B5 on the DC controller PCB when the scanner is at PS1?
