iR4570 Print Out not Even
  • brianho80
    • Sep 2009
    • 198
    Hi Experts,
    does anyone encounter problem like the attachments I uploads here?
    At first I thought is the magnetic roller at DV so I replaced the whole DV (Used) but problem remain the same.
    Will it caused by the Drum or some contacts on the HVT ?
    anyone can advice?
    • 22999
    Re: iR4570 Print Out not Even
    Sounds like a drum ground problem to me. Look here: http://www.copytechnet.com/forums/ca...well-sort.html
    • canonbundy
      • Jun 2012
      • 607
      Originally posted by brianho80
      Hi Experts,
      anyone can advice?
      [ATTACH=CONFIG]21748[/ATTACH][ATTACH=CONFIG]21749[/ATTACH]
      Use OEM Drum Units - after market units are notorious for this problem.
      • brianho80
        • Sep 2009
        • 198
        Hi guys,
        i have try to replace the drum unit today, No Luck ~~ problem remains the same.
        did try to clean up contact points and transfer roller as well, still the same.
        lastly, i replace the toners in the DV tank together with toner bottle and run toner supply. It looks better and toner look even now.
        well, still need to monitor for a period of times to see how the results.
        Thank for all the advice...
