Hai friends & seniers i have one issue in ir2520 , that is , when we make multible copies on dadf , after some more copies the message comes --- memory full--- and the error e202 also comes . On the platen glass no problem . Issue only on dadf & only when we make multible copies . Can any one help me to solve this . Thanks.
Ir 2520 memory full issue
Re: Ir 2520 memory full issue
First Check that the correct Driver is loaded on the PC.
next if driver is OK !!!!!!!!!!!!!
machine displays a message that says "memory full" and also an E202 which indicates that there is an error with the Contact Image Sensor home position.
Replace the Paper Feeder Assembly in the document feeder. Part number FM4-3442-000**Knowledge is time consuming, exhausting and costly for a trained Tech.**
