IR105 Network Assistance
  • bigtone559
    • Jul 2025
    Greetings,
    We've had a IR105 for quite some time now and have been using it as a stand alone machine. We'd like to begin printing to it via the network. however, we're faced with the following problems.
    1. We assign a static IP address to the machine (192.168.16.136)
    2. we're able to ping the printer (as well as ping workstations from the printer)
    3. we install the printer (using the PCL 6 driver win7)
    however, none of the print jobs reach the printer.
    Please Help!
    Thanks!
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: IR105 Network Assistance
    Do you know if it has a printer kit. Needs a printer kit if you want to print via network.
    • bigtone559
      TBH i'm not sure. Would i be able to ping the machine and install the printer (windows communicates with the printer) without the print kit? Could you suggest a method to check?
      thanks,
      • SCREWTAPE
        East Coast Imaging
        • 3396
        thanks,
        Give me a minute.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          You can ping or setup a printer with all the configurations. But with out the printer kit, nothing is coming out.
          Most models within the counter check -Button there is a device configuration tab.
          Within here should find something pertaining to a printer kit.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            And also with service mode
            /additional functions/2&8/additional functions.
            Copier/version/
            Bootrom should say (N)
            iR-105 Hardware Page
            DC-CON 10.06
            R-CON 10.01
            ADF 7.01
            K1N/K2N/K3N IC 106 24.01, IC 125 22.01
            K1/K2/K3 IC 106 04.03, IC125 04.01
            Saddle 04.05
            MN-CONT (System) 71.01
            BOOT-ROM 13.33N
            RUI 70.20
            Language 71.01
            • bigtone559
              Copier/version/
              DC-CON 10.06
              R-CON 10.01
              ADF 7.01
              Saddle 04.05
              BOOT-ROM 13.33N
              RUI 70.20
              Language 71.01
              By the way SCREWTAPE thanks for the replies. I checked our system and it says 26.44C. Does this confirm that the printer kit isn't installed?
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Yea sorry you do not have a N chip.
                C bootrom / Standalone
                i can probably check if there available for you.
                • teckat
                  • 16083
                  Greetings,
                  Please Help!
                  Thanks!
                  Network Boot DIMM===========need Kit
                  imageRUNNER 105 = Multi PDL PRINTER KIT B4/5= 6935-A012-AA
