Ir7105 Canon
  • Rakesh Khambholja
    • Sep 2013
    • 17
    [Jamming] Ir7105 Canon
    Dear all,
    I have Canon Ir7105 machine. Paper is get jammed when take from tray 1, tray 3, tray 4 only A4 size. But when i put A4 R paper in tray 3 and 4 it working fine. Even from 2 nd duck ( left side) the A4 paper working fine. Can any body suggest what is the problem.
  • Iommanxman
    • Aug 2009
    • 180
    Re: Ir7105 Canon
    Hi Rakesh,
    The Jam codes would be useful if you can get them.
    Cheers.
    • Rakesh Khambholja
      • Sep 2013
      • 17
      Re: Ir7105 Canon
      Jam code 0114 from tray 1
      • Iommanxman
        • Aug 2009
        • 180
        Re: Ir7105 Canon
        Lets stick to the other thread.
        • Canuck
          Tech Specialist
          • 1713
          Re: Ir7105 Canon
          Initialize deck and cassette sensors and see if they a;ll pass. If tray 2 fails,make sure prism on metal plate(the one you remove to change rolls) is clean and that the transmitter and receiver in the pickup assembly are not dirty or out of position. If longer paper feeds maybe vertical clutch not working(pickup pushes paper along on longer paper). Clean the vertical clutches,reseat their connectors
