Can default print screen be changed on a Canon C2230i?
  • fotocom
    • Nov 2008
    • 96
    Can the MFP's print screen default be changed from time and job name to time and user name.
    This would avoid confusion for end users, when printing using the secure print mode.
    I hope the attachment with help to make sense of the question.
    Many thanks in Advance
  • teckat
    • 16083
    Re: Can default print screen be changed on a Canon C2230i?
    look here--
    1) Select [Settings/Registration].
    2) Select [Login].
    3) Enter System Manager ID and System Pin and hit [Login].
    4) Select [Preferences].
    5) Select [Display Settings].
    or
    You can set whether to display job logs from the Status Monitor/Cancel screen.
    1. Press (Settings/Registration) → [Management Settings] → [Device Management] → [Display Log].
    2. Select [On] or [Off].
    [On]: Job logs are displayed.
    [Off]: Job logs are not displayed.
    If you select [On]:
    - Press [OK].
    If you select [Off]:
    -Select [Allow] or [Do Not Allow] for → press [OK].
    [Allow]: Allows collection of job logs using management software.
    [Do Not Allow]: Does not allow collection of job logs using management software.
    • fotocom
      • Nov 2008
      • 96
      Originally posted by teckat
      look here--
      2) Select [Login].
      or
      If you select [On]:
      - Press [OK].
      Thanks so much teckat. You and absolute star.
      For an extra bonus point I have another secure print issue.
      I added another post http://www.copytechnet.com/forums/ca...ing-issue.html
      Could you have a look.
      Thanks a million for your help and your valued time.
