How much is an Original Nethawk cable worth to anyone? I'm thinking about switching to windows 7 for the work PC.
Nethawk Cable worth. Not for sale. ?
Re: Nethawk Cable worth. Not for sale. ?
NOTE:
if the original cable was replaced with a new NetHawk cable. Each NetHawk cable is a unique USB item. As a result, if you swapped NetHawk cables and are now using a new (replacement) NetHawk cable, please treat it like new hardware. Remove the 'NetHawk Device' item from Windows Device Manager and reinstall the NetHawk-10 driver from scratch with the new NetHawk cable connected to the USB port on the PC.
UPDATE:
USB-Parallel cable (FY9-4368-000) supports Windows Vista with Service Support Tool (SST) v4.22 or above.
USB-Parallel cable (FY9-4154-000) does not support Windows Vista regardless of the version of SST.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
