canon ipf710
  • mramlawi
    • Jul 2011
    • 838
    canon ipf710
    Dear all ,
    i have a problem with the IPF 710 the problem is when trying to print a monochrome black map the map appear color grey instead black ,and the dizzy thing is when trying to make a status print from the machine the balck color appear correctly ,just on the pc gives grey instead black also if i make a test print from the pc it gives a grey color is theres something must do to solve this i heard from me friend there an option on the driver i can control the lines color but actully i didnt find it .must i update the driver ? btw i also installed the driver at another pc and same problem ,i asked my client and he told me that it happened suddenly .
    Distinguished road makes you jewel in rough
  • alexctx
    • Dec 2010
    • 157
    Re: canon ipf710
    commands the driver as. coated paper.
    loading paper in the 710 as. coated paper
    monochromatic
    • mramlawi
      • Jul 2011
      • 838
      Re: canon ipf710
      i already tryied both to put a cut sheet plain paper and roll plain m not using the coated
      • V-P
        • Apr 2011
        • 679
        Re: canon ipf710
        Are you printing from Autocad ?
        If yes - Select "monochrome" from CAD Print Dialog. It helps
        • alexctx
          • Dec 2010
          • 157
          Re: canon ipf710
          load the paper as it were. coated. because in that role because if you use the. black color. and Select "monochrome
          • mramlawi
            • Jul 2011
            • 838
            Re: canon ipf710
            thanks my friend today i went again and i checked it and noticed that the mbk not appeared on nozzle i will check the tubes maybe it get vocum .
            thanks for your response dude
