IRC 2620N Printouts with thin lines
  • northernlife
    • Sep 2011
    • 847
    #16
    Re: IRC 2620N Printouts with thin lines
    If pg's are having lines on it and the laser is cleaned with that wand doodad, I'd try another laser assembly from a working machine if you have such a luxury available to you. I'd do a pprint and clear the dcon before changing parts though. Sometimes the dcon's keep some weird setting that causes weird issues like this.
    • teckat
      • 16083
      #17
      Originally posted by mkarip
      Dear Canon.Tech
      Its definetly not a drum problem, because i have change it with several black drums in good condition. Color of Thin Lines is only black, no other colors. Lines occurs with prints + copys..see earlier answer
      All PG colors with lines..
      In my opinion problem is black drum motor or black laser..what you think
      cross-feed direction (MAIN SCAN) lines that are in the image area as well as the non-image area.
      --only on prints.
      Black Lines in the crossfeed direction only on prints.
      Check/Inspect the wire harness from the DC Controller to the BLACK laser
      U can also SWAP LASERS TO CHECK
      • Canuck
        Tech Specialist
        • 1713
        #18
        I would like to see pg 5 in each separate color posted. Can't see if line goes through blanking also on these samples. Check what Teckat posted
        • mkarip
          • Feb 2010
          • 33
          #19
          Problem solved..Black Laser was the Problem.
          Thank you all for your support
          • teckat
            • 16083
            #20
            note-------------
            when u replace a the laser unit, execute the following service mode:
            COPIER>FUNCTION>LASER>L-ADJ-0
            • mkarip
              • Feb 2010
              • 33
              #21
              Originally posted by teckat
              note-------------
              Thank you teckat for this reminder..
