IR5570 ADF PROBLEM
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    IR5570 ADF PROBLEM
    Hi, to all.I have been working on this machine but got problem when copying from the ADF.
    When copying from the ADF using the A4 format the copy is ok,but when i put the copy on
    the A4R format the text is cut off or goes to pick paper from the A3 cassette on auto and
    still cuts off the text.Could someone assist to give proper copy settings from the ADF.
    Thanks.
  • blee
    • 51
    Re: IR5570 ADF PROBLEM
    Can't remember the exact location but Under the Feeder Service Mode there are TRAY-A4 and TRAY-A4R settings. Just select the service mode and then set the ADF guides to that size then push the OK in the lower right corner and machine will set the size correctly. You dont need paper in the ADF to perform this service mode, just make sure guides are set to the correct width for the mode you are performing.
      • Aug 2011
      • 279
      Thanx for the quick response, i will try that when i get back to the machine and give a feed back.
      • Canuck
        Tech Specialist
        • 1713
        Yuppers...that will do it. FEEDER/FUNCTION is where its at
          • Aug 2011
          • 279
          I tried this out but nothing happened,could there be a step am missing out? More ideas welcome.
          • Ron314
            • Apr 2013
            • 97
            Here's some information from the ir5570 service manual regarding this adjustment.
            16.5.2.1 FEEDER List 0009-6356iR5570 / iR6570
            In service mode run through this tab sequence COPIER > FEEDER > FUNCTION till you arrive at the choices listed below. Make sure that you place the matching paper type in the feeder tray before starting the procedure. The procedure takes a few seconds so wait for it to finish.
            TRY-A4
            Use it to execute automatic adjustment of paper width detection
            reference point 1 of the ADF original pickup tray.
            TRY-A5R
            reference print 2 of the ADF original pickup tray.
            TRY-LTR
            TRY-LTRR
            reference point 2 of the ADF original pickup tray.
            Ron
            • alexandretecnico
              • Sep 2013
              • 11
              verifique tambem o atuador na bandeja do adf, as vezes ele fica atuando o sensor que indentifica o A3, podendo ate ocasionar copia branca
              • northernlife
                • Sep 2011
                • 847
                Ron
                You must perform all 4 of these adjustments. You're going to want to do a sens-init as well. And you're going to want to check how the machine is detecting originals
                1. Service Mode Level 1>OPTION>BODY>MODEL-SZ>set to 1 when used in an inch environment.
                2. Service Mode Level 2>OPTION>BODY>SENS-CNF>set to 1 when used in an inch environment.
                3. Run the tray width adjustment for the DADF. Set a LTR paper in the DADF's original tray and set the width guides to match the LTR paper's width and run Service Mode>Feeder>Function>TRY-LTR>press OK. After this run the same adjustment for LTRR. Place a LTRR paper in the DADF's original tray and run Service Mode>Feeder>TRY-LTRR>press OK. After these adjustments have been made power cycle the machine.
                4.Try initializing Common and Copy Settings in Additional Functions.
                  • Aug 2011
                  • 279
                  Thanks so much guys,i will be back on site tomorrow and will give a feedback.
                    • Aug 2011
                    • 279
                    Great job done!Thanks so much Northernlife and all the members that gave in the ideas.I did the above adjustments and the machine worked.
                    • eng.sayied
                      0094 Jam Code: Spring comes off actuator of No.2 read sensor found in DADF-S1 (Rank A)
                      [ Case in the field ]
                      Description
                      Since the spring came off the actuator of No.2 read sensor (PI11), the jam code "0094" persisted.
                      - 0094 Jam Code: Power-on jam in the document feeder side. This machine is programmed to display this jam code when the document feeder starts picking up the first original, not immediate after switch-on of this machine.
                      Field Remedy
                      1. Check if paper gets jammed at a sensor; if so, remove the paper.
                      2. Clean all sensors and then execute the following service mode: Service mode > FEEDER > SENS-INT.
                      3. If the symptom still occurs, check if the spring has come off the actuator of No.2 read sensor (PI11); if so, attach it again.
                      0094 Jam Code and message "Open the feeder cover." occur when using ADF
                      [ Inspected by Canon Inc. ]
                      Description
                      Since the jam code "0094" and the message "Open the feeder cover" appeared when using the ADF, the reader controller data was entered again.
                      - 0094 Jam Code can be displayed when the cover open/close detecting sensor of the ADF detects an unexpected opening of the cover.
                      Cause
                      Since the reader controller data was corrupted, 0094 jam, which was not indicated under normal condition, was indicated.
                      Field Remedy
                      1. In service mode > COPIER > Function > CLEAR > R-CON, select the OK key and turn the main power switch OFF/ON to clear the data of the reader controller PCB.
                      2. Enter the values of the service label (affixed to the backside of the reader front cover) into service modes.
                      2-1. Image read start position adjustment (X direction in fixed reading mode)
                      Service mode > COPIER > Adjust > ADJ-XY >ADJ-X
                      2-2. Image read start position adjustment (Y direction in fixed reading mode)
                      Service mode > COPIER > Adjust > ADJ-XY >ADJ-Y
                      2-3. Shading position adjustment (in fixed reading mode)
                      Service mode > COPIER > Adjust > ADJ-XY > ADJ-S
                      2-4. Feeder mode main scanning position adjustment
                      Service mode > COPIER > Adjust > ADJ-XY > ADJ-Y-DF
                      2-5. ADF stream reading CCD reading position adjustment
                      Service mode > COPIER > Adjust > ADJ-XY > STRD-POS
                      2-6. Density manipulating value adjustment
                      Service mode > COPIER > Adjust > CCD > DFCH-G2
                      Service mode > COPIER > Adjust > CCD > DFCH-G10
                      (After entering the values to these modes, be sure to execute service mode > COPIER > Function > DF-LNR.)
                      2-7. Original stop position adjustment (X direction in stream reading mode)
                      Service mode > FEEDER > Adjust > DOCST
                      2-8. Original feed speed (magnification) adjustment
                      Service mode > FEEDER > Adjust > LA-SPEED
                      3. Execute the following adjustments.
                      3-1. ADF sensor sensitivity adjustment
                      Service mode > FEEDER > Function > SENS-INT
                      3-2. Tray width adjustment
                      Service mode > FEEDER > Function > TRY-A4
                      Service mode > FEEDER > Function > TRY-A5R
                      Service mode > FEEDER > Function > TRY-LTR
                      Service mode > FEEDER > Function > TRY-LTRR
                      3-3. White plate data adjustment
                      Service mode > COPIER > Function > CCD > CCD-ADJ
                      3-4. ADF white level adjustment
                      Service mode > COPIER > Function > CCD > DF-WLVL1
                      Service mode > COPIER > Function > CCD > DF-WLVL2
                      Note: The white plate data adjustment must be performed prior to the ADF white level adjustment.
