Canon IR C3380 - HELP
  • XeNos
    • Jul 2025
    I bought a used printer and it has a Y2 saddle finisher on it. How do i remove this and the optional smaller right had saddle so that i can remove. Need some help here.
    Aaron
  • Ron314
    • Apr 2013
    • 97
    Re: Canon IR C3380 - HELP
    The Y2 is easily removed by undoing the oversized telephone jack that electrically connects it to the copier, it's on the backside and is removed without tools. Then undo all the screws that hold the finisher to the copier and you're done. I'm not sure what you're talking about with the second piece but here's a Pdf file with a parts description page in it so that you can give it a name on the reply post.
    http://www.burtype.com/doc/IR-C2880, C3380 Color Brochure.pdf
    Ron
