Ir4570 scanned image have back ground
  • Matoku
    • 173
    [CQ] Ir4570 scanned image have back ground
    NOW I AM FACING PROBLEM THAT. THE SCANNED IMAGE HAVE BACK GROUND - GOT DOTS WHOLE PAGE-. ( NO SAMPLE IMAGE ATTACHED.) IT ALSO SAME WITH FAX FUNCTION. FOR COPY AND PRINTING THE PROBLEM APPEARS. FOR MORE DETAILS. IT SAME EVEN USING DADF AND PLATEN GLASS.
    FIRST I THOUGHT IT FROM THE DIRTY CIS (SCANNER) I CLEANS IT BUT STILL THE SAME. IF YOU SAY THE READER PCB, HOW IT OK FOR COPY AND PRINTING? SO I HAVE NO IDEA. I TRIED REDUCE THE DENSITY ALSO.
    PLEASE HELP, I AM URGENT.THANKS.
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    Re: Ir4570 scanned image have back ground
    Try this: Remove, inspect and clean drum unit; possibility of defective cleaner assembly spilling toner. Auto clean the fixing unit.
    • teckat
      • 16083
      Background appears on all copies from the glass and internal prints.
      look at this setting
      When background appears on all copies and prints,
      check the settings under COPIER>ADJUST>DEVELOP and confirm a setting of +115 to +120.
      If the setting is at -85 to +30
      > change the setting to reflect the above numbers.
      Point>
      when scanning images----Scan originals in Text/Photo Mode & Increase the resolution above 600 dpi
      • northernlife
        • Sep 2011
        • 847
        Happening on your scans as well? Copier > Adjust > CCD > ccd-adj and df-wlvl1/2 been run?
