E000732-0001 IR7095 help
  • ugaa
    • Mar 2013
    • 26
    I have this proble but got this answer from a member but need more explanation.
    ****Reader communication area. Reseat the cable from reader to print engine for a start****
    can someone help please
    what doeas he mean reseat the cable?
  • gcsbkk
    • Aug 2013
    • 22
    Re: E000732-0001 IR7095 help
    This error mean the signal cable not tight.
    Please try to pull out then put it in again.
    Good luck
    • canonbundy
      • Jun 2012
      • 607
      The Code refers to acommunication error between the Reader & the Controller - reseat or REFIT the Cables.
      If no joy then remove & clean the connectors on all the PCBs that plug into the Controller PCB.
      • CRISTIAN MULLER
        • Feb 2013
        • 145
        Recently i had same problem, what I do was, take out SCSI connect cable from ADF and cleaning well, so after that everything allright.hope this help u.
        • teckat
          • 16083
          1-is the error present right after Start-Up ?
          2-or just when u use the doc feeder ?
          3-do u have the error when u use glass copy ?
          • ugaa
            • Mar 2013
            • 26
            yes right after start-up. thank you
