Repeat Image on ir3235
  • Peter Sim
    • Sep 2008
    • 442
    Hi all,
    Need infor and help .Here attach with the print out:.20131003113750158_0001.pdf20131003113750158_0002.pdf20131003113750158_0003.pdf
    I search thru the forum and found this links,is similar to my problem.http://www.copytechnet.com/forums/ca...ir-3225-a.html
    I perform the clearing the main-con ,dc con,it back to the normal print out for a few days and it come back intermittently again.
    Is the laser unit ir3235 and ir3245 are the same? i know that the main controller are not the same and is expansive.
    So may be can interchange the laser unit first or any idea how to resolve this problem.
    Thank you in advance
  • Canon.Tech
    • Mar 2009
    • 335
    Re: Repeat Image on ir3235
    From your samples it looks like your registration is way out? No repeating image, have you replaced the registration clutch?
    • northernlife
      • Sep 2011
      • 847
      I got taken for a run for this same issue two weeks ago. Change your drum 100% guaranteed it's shorting out. We seem to have gotten some shit gpr-15/16 drums. This is a drum shorting out. Make sure you call Canon as they want to see the drum to.
      • northernlife
        • Sep 2011
        • 847
        Don't change any piece without trying the drum first.
        • Peter Sim
          • Sep 2008
          • 442
          Not yet but will try to replace.Did you the word :citi never sleeps" only one "citi" but print out "citi" it look like repeat image.
          • Peter Sim
            • Sep 2008
            • 442
            will change the drum first to test.
