iR1023if jam 0104
  • MFPTech
    • 486
    iR1023if jam 0104
    Hi,
    iR1023if has both T1 and T2 configured for LTR and the customer wants the auto-continue mode.
    The machine works fine if feeding from T1 and T2 individually; however, the moment T1 is empty and the machine is supposed to auto-continue to T2 the machine shows a false jam (Jam code 0104) and the pick up rollers in T2 fail to pick up the paper.
    Any ideas, please?
    Thanks in advance!
  • Brian8506
    • 1665
    Re: iR1023if jam 0104
    I don't have a manual for that machine to give you a whole lot but it sounds like machine doesn't recognize when tray 1 empties and tries to feed another sheet. Try in reverse order. Start machine with T1 out and reinstall after machine starts feeding from T2. Check and make sure you have a paper out sensor flag.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Originally posted by MFPTech
      Hi,
      Any ideas, please?
      Thanks in advance!
      Here the section for auto drawer select.
      Under common settings in the setting menu.
      • Canuck
        Tech Specialist
        • 1713
        If APS/ADS is not enable,it just won't jump to that drawer to continue. It won't declare a jam. Not the issue. Re-install firmware and ram clear to start
