Ir2200 E602-0004
  • linuxxpwin
    • May 2008
    • 205
    Ir2200 E602-0004
    Does anyone have any information on this Error Message?
    I have reload the SSoftware, that did not work I replace my Hard Drive that did not work, I then replace the DC Controller PCb as instructed but same error message. Never seen this one before. not even in the Manuals.
    Does anyone have any suggestions, I am open to all options
    Thanks in advance.
    Calvert Robertson
    Xerox and Canon Tech
  • djbass
    • May 2008
    • 150
    Don't currently have access to a manual so not sure what that subcode is.
    When you reloaded the system software did you do a HDD format first? I stated in an earlier post I've often had currupted partitions and had to reformat them either via service mode or SST.
    No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
    • linuxxpwin
      • May 2008
      • 205
      yep that was the first thing that was done.
      • djbass
        • May 2008
        • 150
        E602-0004
        An error occurs by checking the Control Table of "Image storage area" when the machine is "ON"
        I would try the following, under service mode goto:
        Copier->Function->System
        Set Chk-Type to 1
        Execute HD-Clear
        Set Chk-Type to 2
        Execute HD-Clear
        Power the copier off then on again.
        Also make sure you are running system software v31.04 or later.
        • linuxxpwin
          • May 2008
          • 205
          what i have is version 43.01system software
          boot version 04.22, 23.40 and 26.44
          Calvert
          • yourownfree
            • Dec 2007
            • 474
            version 45.01 is out and need to use with boot 26.44
            dc controller dimm should be 12.01, rcon 7.01.
            when using sst to format always do it manually not with all_HDF. It does not work. if you can reinstall system software like you said then i would presume the hard drive is good. I dont think you really reinstalled system software properly. format first manually, then select "All" choose the highest version in your system software check your type of cable being used as the last thing to do then select start. You also changed the wrong board. these errors relate to main controller, ram and hard drive not dc controller. one of those three are your problem. try re-downloading before you change anything else. reseat the ram first before you download. if you your ram is shot or you dont have the proper ram installed it will not work, from experience.
            • linuxxpwin
              • May 2008
              • 205
              the board the I replace is the main controller and not the dc controller as far as I can see the software was installed correctly,
              I did a manual format and then installed software..
              Where Can I find the latest version of software?
              personal email address is: linuxxpwin@gmail.com
              • linuxxpwin
                • May 2008
                • 205
                I was reading about a version 50.06!!!!!
                Calvert Robertson
                • yourownfree
                  • Dec 2007
                  • 474
                  where is version 50? I'm looking at the Canon site and there is none yet. maybe just reading about?
                  ir 2000 series(not ir2200) v55.01, 3045 v28.03, 2200/3300 45.01, 3300i 28.01, 3320 38.01, 3530 26.02 HDD/62.02, 2270-4570 v39.01, 5000 v20.01, 5000d v82.03, 5000i v47.01, 5075 v41.01, 5570 v39.01, 6020 v59.01b, 105+/9070 v16.01, 105 v85.02, 7105 v62.01
                  color c5058 v64.02, c3100 v46.01, c3170 v36.01, c6870 v17.05, c6800 v14.01, c3220 v86.01, c2550/2880 v80.26, c5180 v79.01
                  as of 5-26-08
                  I would really check the ram and try a different stick, the proper number not just 256mb, needs to be a certain type. Try and do it all manually, format, rui, language and system. Check all connectors cables and power to the board and hard drive. Something is fishy. Maybe forgot a connector and its behind the board etc. is there any bent pins where the hard drive plugs in, did you move the jumper on the hard drive? dont. are you using a generic hard drive?
                  • linuxxpwin
                    • May 2008
                    • 205
                    can you please send me files my email address is linuxxpwin@gmail.com
                    or direct me as to where i can find the files.
                    Thank you very much in advance.
                    Calvert
                    • linuxxpwin
                      • May 2008
                      • 205
                      Update on error Code
                      Problem was found to be the memory module, after replacing the Hard Drive and Main Controller PCb and reloading software to the latest version, things did not go well, but then I changed my memory with a dell 128MB 133mhz memory and Voila, all is good.
                      Thanks a whole lot to yourownfree for all the help offered it was greatly appreciated.
                      Calvert
                      • yourownfree
                        • Dec 2007
                        • 474
                        your welcome, glad you fixed it.
                        • lkrsardis
                          • Dec 2007
                          • 316
                          bootrom
                          if all else fails get a new boot rom it can fail and no matter what you try it wont work.
                          Like the United States Postal Service It's a miracle it works!
