My Canon IR 6000 cleaning web take-up roller does not turn.
Assuming I have installed it correctly, the empty, take up shaft is on the left and the Full, roller with clean web material is on the right. I removed the take-up shaft motor to check it out. The shaft it's self will not turn in either direction even with some force. For now I run a few thousand copies, then open up the fuser station and manually roll the dirty excess onto the take-up roller. Any suggestions on how to free up the motor driven take up roller?
Thank you for your attention.
Dana Lewis
Dana Lewis
