Greetings. Deputy impressions of a IRC1028iF, the problem is that when I make color copies or prints out only a part the other is blank. What could be the problem?. The engine block is changed. thanks
irc1028iF
Re: irc 1028
Fellow the steps shown in the service manual.
Point to Note When Installing the Main Drive Unit.pdf
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
Re: irc1028iF
Check the Bias Contacts on the ITB and on the frame of the imageRUNNER**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
