SCREEN TABS MISALIGNED (Imagepress C1 & iRC4080i)
  • SAZ911
    • Mar 2013
    • 193
    [Electrical] SCREEN TABS MISALIGNED (Imagepress C1 & iRC4080i)
    hi all,
    Hope you guys can help me out with some info, I have two machines, (Imagepress C1 & iRC 48080i) that have the same problem. The tabs/icons on the display seem to have become misaligned, its as if the whole touch panel has moved up about 2 cm's. so for example if i was to try a press PAPER SELECT i would literally have to press the screen about 2 cm above the paper select icon for it to work.
    My question is, do i replace the screen itself or is it a board (inverter board) issue, because the display itself is perfect.
    thanks for your help,
    SAZ911..........
  • vigour
    • Aug 2010
    • 1038
    Re: SCREEN TABS MISALIGNED (Imagepress C1 & iRC4080i)
    http://www.copytechnet.com/forums/sh...ad.php?t=63981
    • teckat
      • 16083
      Originally posted by SAZ911
      hi all,
      first try this
      in service mode Level 1
      COPIER>FUNCTION>PANEL>TOUCHCHK
      Used to adjust coordinate positions of analog touch panel.
      Operation method
      - Used to align the touch panel touch position with the LCD coordinate position.
      - Perform this service mode item if you have replaced the LCD unit.
      1) Select "TOUCHCHK" to display the item in reverse, then press the OK key.
      2) "+" appears on the touch panel at 9 positions sequentially. After you press each position, adjustment is complete.
      • Hansoon
        • Sep 2007
        • 3381
        Densi has now very good modified after market touch panels:
        for Canon iR2220,iR3300,ir5500,iR6020,iRC2880,IrC3080,
        iRC4080,iRC5058,iRC5800 etc.
        Densi #CATP0001 (OEM: FK2-0246-000, FK2-0329-000)
        Hans
        • SAZ911
          • Mar 2013
          • 193
          Originally posted by teckat
          first try this
          Operation method
          HI TECKAT,
          thanks, tried doing the adjustment, problem is when i go into service mode i can only select feeder, because thats as far up as the screen detects touch, even if i was to get into "COPIER" i would not be able to select the tabs at the top.
          anyways i think ill just have to replace the whole lot......
          cheers...
          SAZ911..........
          • Hansoon
            • Sep 2007
            • 3381
            Only the touchpanel
            Hans
