canon ir 3045 alarm 2 code 5000010 ?
  • Jerrygbs
    • Dec 2008
    • 193
    [Error Code] canon ir 3045 alarm 2 code 5000010 ?
    I can't find this alarm code in my manuals please help.
  • teckat
    • 16083
    Re: canon ir 3045 alarm 2 code 5000010 ?
    test if u can print internal prints
    P-Prints, Test Prints, User Data List or ID Print Totals.
    test all
    see if an alarm light would flash > followed with a message
    EXAMPLES
    If a P-Print, or Test Print was selected the alarm light would flash and there was a message "suspended" which could be cleared in the system monitor screen.
    If a ID Print Totals was selected the alarm light would flash and the unit would lock up until the power was cycled.
    If a User Data List was selected the alarm light would flash and there was a message "the output tray is full".
    The alarm code in all cases was 50010 of which there is no description in the service manual.
    In cases-----It was then noticed that someone had enabled tray 3 (the right side exit) and selected tray 3 as the tray designation for "Other Prints" which includes all internal prints. In this case tray 3 had the cover on and was unavailable as an exit.
    If messages are received > check your tray designation for "Other Prints"/ make sure that the selected tray is available
    • Jerrygbs
      • Dec 2008
      • 193
      test all
      EXAMPLES
      All test prints exit appropriately, small script bubble at bottom left of touch pad. /??//
      • Jerrygbs
        • Dec 2008
        • 193
        fixed by mmi clear and firmware update..
