E0051-0001
  • romel85
    • Aug 2025
    [Error Code] E0051-0001
    Good Day!
    Im having a serious trouble with my CANON ir c5870 always having a paper jam followed by and error code E0051-00001.
    I have clean all the sensor with air blower and some replace it with new one. by still code appear i have already clear the error.
    Plz someone help me
    Thank you...!
  • romel85
    Re: E0051-0001
    Were i can find the horizontal registration home position.
    it say that the horizontal registration home position is not detected within a specific period of time.
    • canonbundy
      • Jun 2012
      • 607
      Re: E0051-0001
      A couple of Tech Cases - hope they help.
      In this case, a bent guide in the duplex path was blocking the actuation of the horizontal registration sensor (PS24); resulting in the error code. Once the actuation of the sensor was set back to normal the error code was resolved.
      Symptom
      The E051 is a side registration home position error. This error occurs while the M28 horizontal registration motor moves the horizontal registration plate to the home position. The horizontal registration home position sensor PS24 fails to detect the plate thus generating the E051 error code.
      Cause
      In this case, the Gear listed in Figure 272, Key Number 6, had a few teeth missing preventing the gear from being driven.
      Action
      Replace the gear with a new one (FS6-0557-000).
      • teckat
        • 16083
        Re: E0051-0001
        Originally posted by romel85
        Good Day!
        Plz someone help me
        Thank you...!
        Check for any jammed paper in Duplex Area
        1. Check PS24 (horizontal registration sensor) for correct position and any fallen paper.
        2. Check M28 (Horizontal Registration Motor) for operation.
        Service Mode > COPIER > FUNCTION > PART-CHK > MTR #28
        FK2-0163-000 M28
        FL2-2480-000 PS24
        Here is a pic of GEAR location posted by canonbundy
        • ajaybhagat2889
          • Mar 2019
          • 17
          Re: E0051-0001 in IR 7105
          sir I am tired of E 00051 because ... as I show problems with horizontal registration sensors, I tried the and change duplex unit on another machine ... however ... the duplex jam is showing and then after removing the duplex the machine gets warm and then the E00051- 0001 This error is coming ... As you mentioned I have also changed the MSW5 switch but the error does not go .... Please help me.
          • teckat
            • 16083
            model ??
            • ajaybhagat2889
              • Mar 2019
              • 17
              Originally posted by teckat
              model ??
              Ir 7105
              • ajaybhagat2889
                • Mar 2019
                • 17
                Ir 7105
                Ir 7105 and E00051-0001 is proscribed again and again........... I have three ir 7105 machines. So for the first time I tried replacing the duplex, then I changed the MSW5 switch as you mentioned and then I first changed the DC board. But the problem is coming along .We just wanted to try to replace the previous connector which is a duplex to mashine connector...... what i do?
                • ajaybhagat2889
                  • Mar 2019
                  • 17
                  model ??
                  Canon IR 7105 this model and Erorr code E00051-0001
                  • ajaybhagat2889
                    • Mar 2019
                    • 17
                    Ir 7105
                    Sir please reply
                    • teckat
                      • 16083
                      Sir please reply
                      Do not see anything added by Canon.
                      U are going to recheck all connections
                      • wcanonw
                        • Aug 2014
                        • 404
                        Error E051: The horizontal registration HP detection has an error.
                        sub code 0001- After the start of horizontal registration HP detection,
                        the HP sensor is not off within 5 sec
                        (i.e., not leaving home position).
                        MEMO:
                        Remedial action: If an error is detected in the course of horizontal
                        registration HP detection at power-on, the
                        machine will indicate the presence of a jam.
                        At the start of horizontal registration
                        detection in the course of printing, the
                        horizontal
                        registration detection operation for
                        downstream paper does not end within 5
                        sec.
                        sub code 0003 - Replace the horizontal registration HP sensor. Replace
                        the horizontal registration motor.
                        Replace the stackless transport driver PCB. Replace
                        the DC controller PCB.
                        • wcanonw
                          • Aug 2014
                          • 404
                          Re: E0051-0001
                          The horizontal registration sensor moves to the start position (A4 detection position) when the main power
                          switch is turned on or the front cover is closed, and moves to a detection position to suit the size of paper
                          expected in the lower feeding assembly. Its position of etection is "paper width +2 mm."
                          The paper detection mechanism starts when paper moved to the lower feeding assembly has moved past
                          the confluence sensor (PI 15) and has been moved over a specific distance (about 10mm past the horizontal
                          registration sensor).
                          The position of paper is detected with reference to the start position and by finding out the difference between
                          the start position and the actual paper position from the number of drive pulses (1 pulse = about 0.16
                          mm) of the motor.
                          Related service mode COPIER > ADJUST > FEED-ADJ > ADJ-REFE
                          • ajaybhagat2889
                            • Mar 2019
                            • 17
                            Re: E0051-0001
                            mm) of the motor.
                            Sir i attach image you see it
                            • ajaybhagat2889
                              • Mar 2019
                              • 17
                              Re: E0051-0001
                              mm) of the motor.
                              We have three mashines same... i have change 3 duplex of other mashine but... mashine gone that shows jam
