Calibrating scanner colors on IR advance 5030
  • crwoo
    • 76
    Hi, I have a image runner advance where when i scan a black sheet in color mode it will have the top part blue. I have concluded it is the scanner because whenever I print the colors are fine. but scanning and copying are blue. Attached is a scan of what I am talking about.
    Any help would be appreciated.
  • teckat
    • 16083
    Re: Calibrating scanner colors on IR advance 5030
    attachments don't open----site issue
    proper sequence to calibrate
    the sequence is to do an AUTO COLOR MISMATCH first, then a CORRECT SHADING, followed by a full AUTO GRADATION,
    then COLOR CALIBRATION for the image Pass/Fiery-or ColorPass.
    note:
    CORRECT SHADING and COLOR CALIBRATION should be performed using a Spectrophotometer (i1 Basic Pro).
    There are 3 types of shading correction you can do on a imageRUNNER ADVANCED Series copier.
    1)Densitometer Correction
    2)Visual Correction
    3)Print Server Correction
    • crwoo
      • 76
      thanks for the reply, is that to calibrate scanner or the printer? the printer colors are great when printing from computer. the problem is with the scanner only.
      • teckat
        • 16083
        This is a complete procedure------------
        • crwoo
          • 76
          whats the best way to do the correct shading? I do not have a Densitometer. so what would be best way to do it by visual correction?
          • charm5496
            • 2387
            the shading correction does not apply to your scanner adjustments.
            You say you are placing a black original on your glass and it is coming out with blue tones. What does the output look like when you place a full color original on the glass?
            In order to get good copy quality you have to run the auto gradation and choose the proper original type for the scanner to get the proper DPI when scanning the originals.
            Another setting that we always set on these units to help with the copy quality is go to service mode copier>option>FN-SW>IMGCNTPR - 0
            cycle power
            run auto gradation
            test
            • crwoo
              • 76
              hi
              when i place a full color photo on the glass and copy or scan to computer half the sheet is very nice and towards the top the black starts fading and the black starts fading to blueish. all prints from computer are very nice. i tried your instructions and that didnt help. physically the scanner looks to be in perfect condition.
              • crwoo
                • 76
                oo
                • teckat
                  • 16083
                  hi
                  U can't just look at a Laser Scanner Unit & determine it looks good/ that's like kicking the tires
                  • crwoo
                    • 76
                    I understand. do you think it's the scanner unit? ever heard of the scanner unit scanning much lighter or tinting certain colors on one side?
                    • charm5496
                      • 2387
                      do you have a manual on this machine? Support the website and click on the banner at the top of the page if you need a manual....
                      If not it might be time invest in that or pay someone to come out and take a look at the machine for you. Sounds like you need to clean the scanner and run the adjustments on it
                      • mapsanji
                        • 12
                        Inside the scanner you have mirrors, clean them!
                          • 37433
                          Right click on the attachment. Click on "Save Link As" in Firefox or "Save Target As" in IE. Save the file where you can find it easily. Open the file.
                          • teckat
                            • 16083
                            __:
                            Try that on a SMARTPHONE ) (;
                            already know that maneuver from dos days
                            save as > to PC comes up as invalid image/ as I said personal folder inserts do no open
                            • teckat
                              • 16083
                              why don't u try that > then post image
